TurboS60 Posted September 15, 2009 Report Share Posted September 15, 2009 So lately ive been getting a metal on metal sound coming from my front drivers side wheel going over bumps. After checking it out it seems my brake pad has come loose and you can physically move it slightly. Also, with the brakes pressed slightly the noise goes away. So is there any way to fix this without taking the caliper off the rotor. Ill also add im getting vibration at highway speeds so could i suspect this to be the problem. Thanks! Link to comment Share on other sites More sharing options...
MrWinkey Posted September 15, 2009 Report Share Posted September 15, 2009 Factory pads Link to comment Share on other sites More sharing options...
TurboS60 Posted September 16, 2009 Author Report Share Posted September 16, 2009 Factory pads No i have Akebonos but problem solved, the retaining pin on the caliper came out of position causing the pad to move around freely. I didnt realize that pin held the pad in that much! Link to comment Share on other sites More sharing options...
