Tom. Posted September 20, 2009 Report Share Posted September 20, 2009 the problem is the rear seat in the R (the smaller of the two sides behind the driver seat) the seatbelt is almost like it rolled up way to much and wont release. and as a result i cannot put the seat in the fully upright position... my indie shop told me that best bet would be to replace the entire assembly... he said something about a internal button or something... the owner of the car claims it happened before and they somehow fixed it but he cannot recall how... any thoughts? this happen to anyone? i wont have the car till Tuesday or wendsday i plan to take it apart and look at it then. but any advice would be nice! to replace the assembly is like 300+$ so im hoping someone can tell me how to fix it... Link to comment Share on other sites More sharing options...
2005V70R Posted September 23, 2009 Report Share Posted September 23, 2009 the problem is the rear seat in the R (the smaller of the two sides behind the driver seat) the seatbelt is almost like it rolled up way to much and wont release. and as a result i cannot put the seat in the fully upright position... my indie shop told me that best bet would be to replace the entire assembly... he said something about a internal button or something... the owner of the car claims it happened before and they somehow fixed it but he cannot recall how... any thoughts? this happen to anyone? i wont have the car till Tuesday or wendsday i plan to take it apart and look at it then. but any advice would be nice! to replace the assembly is like 300+$ so im hoping someone can tell me how to fix it... Mine does this...temp fix is to unbolt seat belt from side bottom mount (15mm I believe) and then it will retract. But the problem will come back. Link to comment Share on other sites More sharing options...
Tom. Posted September 23, 2009 Author Report Share Posted September 23, 2009 yup thats what i did. good enough for me! i wont be using it to often Link to comment Share on other sites More sharing options...
Guest mbardall Posted December 25, 2010 Report Share Posted December 25, 2010 My 2001 has the same issue!! Ugh. I was going to take it apart but I guess I should just order a seat belt idk. Link to comment Share on other sites More sharing options...
Guest mbardall Posted December 25, 2010 Report Share Posted December 25, 2010 check this out this might help. I am going to try it on mine today. http://www.brickboard.com/AWD/volvo/1420380/XC50/XC60/XC70/XC90/rear_seat_belt_ratchet_releasing.html Link to comment Share on other sites More sharing options...
Guest mbardall Posted December 25, 2010 Report Share Posted December 25, 2010 It worked! I found out that I was missing a knob that stops it from receding into the seat further than it should. Nice to know. Link to comment Share on other sites More sharing options...
831t5r Posted December 26, 2010 Report Share Posted December 26, 2010 Ya common for stop button to break or go under the plastic covr. Unbolt and melt a new one in, I got special bit for my soldering gun to melt em. They r cheap to replace too Link to comment Share on other sites More sharing options...
JRL Posted December 27, 2010 Report Share Posted December 27, 2010 EXTERNAL button Probably the little plastic button(s)have broken off, allowing the belt to retract all the way (and lock). You need to remove the side (or the seat) to get it out and then install new buttons. Link to comment Share on other sites More sharing options...
Keaton85 Posted December 28, 2010 Report Share Posted December 28, 2010 On my moms XC the plastic is all broken off so she had to stick a massive button onto it. Only problem with that is only skinny people can sit in the seat now! Haha Link to comment Share on other sites More sharing options...
