loseR99 Posted September 24, 2009 Report Share Posted September 24, 2009 So i just got this car last week, twice the coolant level sensor light has come up. Topped it off, everything went away, light is back on, found a leak on the passenger side of the radiator about halfway down the end tank. I've found some replacement radiators at decent prices but was wondering if anything else needs to be replaced while it was out? Any of the the AT line clips or o-rings? Good time to replace radiator hoses, thermostat, gasket, etc. Anyone that's done this I'd like to get a comprehensive list of parts I'll be needing. Any info is greatly appreciated, thanks, Adam Link to comment Share on other sites More sharing options...
RickyRacer Posted September 24, 2009 Report Share Posted September 24, 2009 I just bought a 2000 v70r. Same thing radiator was leaking passenger side below the hose. I bought 2 after market radiators and they were both wrong. I just got the factory one and it fit perfect. I have owned this car about 2 weeks the timing belt was just done. Here's the same list I did on the car in the last 2 weeks it runs great. This might help you radiator b plus power cable(goes from battery to fuse box) mine was corroded/ comon problem springs for brake pads(missing) upper motor mount by fire wall lower motor mount below timing cover spark plugs right control arm both sway bars links flush tranny fluid with factory synteic fluid all brakes pads & rotor 3rd seat tires Link to comment Share on other sites More sharing options...
MrWinkey Posted September 26, 2009 Report Share Posted September 26, 2009 You certainly might want to have the green line clips on hand for the cooler lines as they can tend to break. New line o-rings are always a good idea as well. As for hoses and t-stat all optional and depends on condition and mileage on car. Link to comment Share on other sites More sharing options...
