Hussein's 1998 V70 Xr : The Force Awakens
lookforjoe
Time to try some LS2 coils. I had fantastic results with them.
Or LS7's
Do you guys have specific PN's for these? Or do I just do a general search for LS2/7? Do they use three wire like the Bosch? Do they need a heat sink rail?
Truck Coils?? Each coil does two cylinders?
EDIT: LS1Tech info
D585 are supposed to be the best.
http://www.ebay.com/itm/GM-Gen-3-5-3-6-0-Lq4-Lq9-Lsx-D585-Ignition-Coils-/251676345925?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a99144645&vxp=mtr
1000whp GTO at our shop is running them, upgraded from the LS2 coils I am running.
That's what the truck coil is listed as - that is one per cylinder?
>Found Trents' setup
Justus - what did you do for dwell times/tables?
Those stock T5 coils from bosch are tested to be good for 250hp per coil so i dont think that coil is the problem and this is with e85 ethanol fuel which is much harder to ignite.
Check also your cam timing. How much is intake and exhaust cam open in TDC in millimeters thanks? :)
Edited by VulvaS40T4
Thanks. Good to note. I have had the Bosch Motorsport Coils fail, which is what I was referring to.
Cams are set per Enem recommendation:
1.2mm EXH 1.5mm INT
Set on True TDC on #3 not by Volvo markers :)
In between the thunder showers I replaced the BMS coil packs with the OEM Volvo packs I had bought & run for around 10k prior to installing the BMS coils.
So, new DPP+ fine wire plugs @.026", and now the coil packs. With this, the breakup/stutter and idle are all gone. I would need to reinstall the BMS coils one at a time to determine where the fault lies. Not sure I care to bother .
I think I'll get a set if the D 585's & build an alternate coil array. With TunerPro, I can adjust the dwell maps ( with help) . I just need to get the onboard COP working in place of the add on TT COP I'm using now.
Going to order a new air filter & make a new can to fit - I can get away with the 9.5" tapered cone I listed in Simply Volvo's thread RU-5045 flows 1127cfm, VS 1186 of the one VulvaS40T5 is using, which I would have trouble fitting as it is 7x9 cylinder, VS cone (6.75x9.5 w/5.875 base OD) >Reference post
0387E445-2F7D-4200-B474-2EFBF8D054DA_zps
Also need to fit this & make new DP to match the WG offset
>Original LGSpeed Header Install Thread
5D7556C4-2813-4A39-A0B8-F2042D444957_zps
And maybe I'll fit my crank scrapers/windage kit while it's down
740A381B-168C-4423-9801-9552F20FDAE2_zps
Guest
Reply to this topic...
  Only 75 emoji are allowed.
