Young Burnsy Posted October 4, 2009 Report Share Posted October 4, 2009 Hey, So my car has been vibrating at or above speeds of 45 MPH, it is most noticeable after 60 MPH. I was hoping that replacing the transmission engine mount would make a difference but I don't think it did. This vibration comes only from the left front wheel under load/acceleration. It happens with and with out cruise control. I think it is the worst when accelerating between 60-75 MPH or travelling at those speeds. I don't think it is the wheel since it doesn't vibrate when coasting. I am not sure what else to check although I will rotate the wheels next weekend, front to back. Also it seems to vibrate worse when the car is loaded. I imagine this is probably some bushing issue? I don't think it's serious, but it annoys the shit out of me. Where do I start looking? Link to comment Share on other sites More sharing options...
s60wot Posted October 4, 2009 Report Share Posted October 4, 2009 cv axles? Link to comment Share on other sites More sharing options...
Young Burnsy Posted October 4, 2009 Author Report Share Posted October 4, 2009 cv axles? I hope not but how do I check? Link to comment Share on other sites More sharing options...
MrWinkey Posted October 4, 2009 Report Share Posted October 4, 2009 I hope not but how do I check? You need a RH(I think) axle inner driver is shot ;) Link to comment Share on other sites More sharing options...
s60wot Posted October 5, 2009 Report Share Posted October 5, 2009 cv axles? Grab the axle and give it a shake You will be able to feel if it's bad Also, you may have some grinding or crunching sounds turning a low/slow speeds Link to comment Share on other sites More sharing options...
MrWinkey Posted October 5, 2009 Report Share Posted October 5, 2009 Grab the axle and give it a shake You will be able to feel if it's bad Also, you may have some grinding or crunching sounds turning a low/slow speeds Sigh. Link to comment Share on other sites More sharing options...
rbodor3 Posted October 5, 2009 Report Share Posted October 5, 2009 jack up the front end and grab the wheel in the 3 & 9 positions and try to move it. Do the same from the 12 and 6 positions. This will help you determine where the give is coming from. Could be tons of different things. I'd start with rotate, balance, & align the tires. Check for unusual tread wear also. This is the #1 cause. Then go on to what components have gone bad (my first guess - lower control arm bushings). Link to comment Share on other sites More sharing options...
T5wagon1717 Posted October 6, 2009 Report Share Posted October 6, 2009 Hey, So my car has been vibrating at or above speeds of 45 MPH, it is most noticeable after 60 MPH. I was hoping that replacing the transmission engine mount would make a difference but I don't think it did. This vibration comes only from the left front wheel under load/acceleration. It happens with and with out cruise control. I think it is the worst when accelerating between 60-75 MPH or travelling at those speeds. I don't think it is the wheel since it doesn't vibrate when coasting. I am not sure what else to check although I will rotate the wheels next weekend, front to back. Also it seems to vibrate worse when the car is loaded. I imagine this is probably some bushing issue? I don't think it's serious, but it annoys the stuff out of me. Where do I start looking? Hey, I have this exact same problem with my 99 S70 glt. Its not the alignment or the tires. It also does it only under load, however mine is worse between 50-65. I replaced the top engine mount just because it was shot and so I did, but it did not help at all. The tie rods were replaced a few months ago, so I am pretty sure I can rule those out too. Everyone who replied to my post said cv. Keep me apprised as to what you find out and I will do the same. Teal Link to comment Share on other sites More sharing options...
MrWinkey Posted October 8, 2009 Report Share Posted October 8, 2009 Sigh again Link to comment Share on other sites More sharing options...
rbodor3 Posted October 15, 2009 Report Share Posted October 15, 2009 Cracked my CV boot over the weekend, but was forced to drive 600 miles because I was on a road trip on the way home. I replaced the boot once before because of a rock, but due to the amount of miles I had to drive on it didn't want to chance it. Just replaced the entire axle earlier today. But while highway driving, lots of boost lots of WOT btw, I noticed the car pulled left under braking. I assume was because of the axle bearing getting wore down (passenger's side). But I replaced it today - still pulls left but not as hard. Possible the driver's axle needs some R&R also? Link to comment Share on other sites More sharing options...
