Pops Racer Posted October 6, 2009 Report Share Posted October 6, 2009 Oil is evident on the rear of the crankcase. I thought it was the drain plug washer leaking at first, but now it appears the leak only occurs when the car is running down the road. It's making a mess under the car and blowing up on the tailgate and rear bumper. Just looking for possible issues. Turbo was swapped so I also suspect the return line O-ring, but nothing conclusive. Again it only drips on the driveway after a run. And no oil on top of valve cover. Link to comment Share on other sites More sharing options...
Dave 54 Posted October 6, 2009 Report Share Posted October 6, 2009 Mines doing the same, only on long highway trips. I replaced the return seals cause they were leaking. Helped some but still get it, I reached up around the turbo inlet line and the rubber junction hose there felt wet so that's my next step, may want to feel around there and check. Link to comment Share on other sites More sharing options...
Budnapp Posted October 6, 2009 Report Share Posted October 6, 2009 It is probably the turbo return line O-ring that goes back to the oil pan. This is what it was on mine. I just put a new O-ring in and it leaked like a waterfall. Took everything back apart again and found that the O-ring got ripped somehow. Replaced it again with no problems sence. Good luck Link to comment Share on other sites More sharing options...
Pops Racer Posted October 7, 2009 Author Report Share Posted October 7, 2009 It is probably the turbo return line O-ring that goes back to the oil pan. This is what it was on mine. I just put a new O-ring in and it leaked like a waterfall. Took everything back apart again and found that the O-ring got ripped somehow. Replaced it again with no problems sence. Good luck Thats where the smart money is right now. I called my indie and he thinks the same, also suggested RMS, but he did that less than 50k miles ago, and no leaking on drivers side when car is parked, so I'm dropping it at his garage for a no-charge diagnosis. I love my indie. Thanks for the input. Link to comment Share on other sites More sharing options...
beadgc23 Posted October 7, 2009 Report Share Posted October 7, 2009 RMS? God forbid - that should be a once in a lifetime job...(per car...) Glad I got mine over with! Link to comment Share on other sites More sharing options...
Modus Posted October 7, 2009 Report Share Posted October 7, 2009 If it was the RMS it wouldn't blow oil that high. Does your oil leak look like this>? If it does, and only is noticed when your car is in motion then it's more than likely your axle seal. As it was mine. Link to comment Share on other sites More sharing options...
erikv11 Posted October 7, 2009 Report Share Posted October 7, 2009 but it sure sounds like the OP knows the car is leaking oil, not trans fluid. Like, no doubt the first thing was to monitor the oil level on the dipstick? Link to comment Share on other sites More sharing options...
whitesnake Posted October 7, 2009 Report Share Posted October 7, 2009 HEY!!! I might have the same problem on, I was told its the oil drain is blocked its a black plastic box and i was shown one from another car which had oil caked inside. However mine does not spray back as far as yours. anyone know where to locate this drainage thingo is? Link to comment Share on other sites More sharing options...
erikv11 Posted October 7, 2009 Report Share Posted October 7, 2009 I might have the same problem on, I was told its the oil drain is blocked its a black plastic box and i was shown one from another car which had oil caked inside. However mine does not spray back as far as yours. anyone know where to locate this drainage thingo is? you are talking about the oil trap. It is the heart of the PCV system in these cars, it is attached to the block below the intake manifold. There are pinned threads about it start there. Link to comment Share on other sites More sharing options...
Pops Racer Posted October 7, 2009 Author Report Share Posted October 7, 2009 PCV, Tbelt and related components, serp belt, and RMS all done at the same mileage, ~160k miles. 200k now. Nothing on top of turbo, new oil fill cap gasket and dipstick Orings, and dipstick tube oring. Oil cooler seals and Orings new with radiator this past spring, so it's a pretty limited possibilities. Def engine oil, not tranny. I'm hoping/praying it is O-ring on return line. Like I said we just did this in July, but the leak did not show up until about 4 weeks ago. I'll know Friday PM. Meanwhile she gets a flow of new oil on a regular basis! AutoZone has/had a good deal on M1 with purchase of a filter. I got the 5+ gallon jug which = 5.28 gallons, and it was right in the middle of the dipstick after the change. I think a catch can is in the near future. Link to comment Share on other sites More sharing options...
