Brad850 Posted October 7, 2009 Report Share Posted October 7, 2009 Alright sooo..since my dashboard creaks a lot I decided to pull it apart and follow the pinned thread for repairing it. I began by pulling out the top of the dashboard and the gauge cluster and this is what i found... Sorry for the crappy picture but you get the point. Is there any way I can reconnect it with bondo or something? :ph34r: Link to comment Share on other sites More sharing options...
MyCarIsRed Posted October 7, 2009 Report Share Posted October 7, 2009 from what i can tell it's a plastic panel of sorts? Get 2 mending plates from hware store (like 3/4" x 4" with 4 matching holes, preferably smaller holes). Stick one on with tape, lengthwise across the crack. drill holes through plastic while holding the crack closed. place the other plate on the other side and either pop rivet or bolt them together, sandwiching the plastic. You want the holes in the plates and the holes in the plastic to be as close to the size of the rivet/bolt as possible so it's a nice snug fit. If you use bolts use nyloc nuts and don't go nutzo tightening them, like 1/8 turn past tight will do. You should be able to position the plates so that they don't interfere with anything or rub on the dash pad. If the assembly is nice and snug, and has little to no wiggle room, you'll never think of it again. Link to comment Share on other sites More sharing options...
Brad850 Posted October 7, 2009 Author Report Share Posted October 7, 2009 from what i can tell it's a plastic panel of sorts? Get 2 mending plates from hware store (like 3/4" x 4" with 4 matching holes, preferably smaller holes). Stick one on with tape, lengthwise across the crack. drill holes through plastic while holding the crack closed. place the other plate on the other side and either pop rivet or bolt them together, sandwiching the plastic. You want the holes in the plates and the holes in the plastic to be as close to the size of the rivet/bolt as possible so it's a nice snug fit. If you use bolts use nyloc nuts and don't go nutzo tightening them, like 1/8 turn past tight will do. You should be able to position the plates so that they don't interfere with anything or rub on the dash pad. If the assembly is nice and snug, and has little to no wiggle room, you'll never think of it again. Thank you!! :) Link to comment Share on other sites More sharing options...
BIG DOG Posted October 8, 2009 Report Share Posted October 8, 2009 Another good trick for plastic parts is crazy glue and baking soda .Strong as heck and easy to use get the two together and experiment you will figure out how to use it.The baking soda will harden the glue instantly and it can be built up or filed down and it is strong.Don't get it on anything you don't want glued together ...like your hand and forehead or worse....... Link to comment Share on other sites More sharing options...
MyCarIsRed Posted October 8, 2009 Report Share Posted October 8, 2009 Another good trick for plastic parts is crazy glue and baking soda .Strong as heck and easy to use get the two together and experiment you will figure out how to use it.The baking soda will harden the glue instantly and it can be built up or filed down and it is strong.Don't get it on anything you don't want glued together ...like your hand and forehead or worse....... Im going to have to try that on something... not skin related. Link to comment Share on other sites More sharing options...
Быстров Posted October 8, 2009 Report Share Posted October 8, 2009 Don't get it on anything you don't want glued together ...like your hand and forehead or worse....... hahahahhaha Link to comment Share on other sites More sharing options...
Brad850 Posted October 10, 2009 Author Report Share Posted October 10, 2009 haha wow I just got that joke Link to comment Share on other sites More sharing options...
Быстров Posted October 10, 2009 Report Share Posted October 10, 2009 LOL3RZZ Link to comment Share on other sites More sharing options...
