c_long20 Posted October 8, 2009 Report Share Posted October 8, 2009 I have a 98 V70 AWD, I saw some people are removing the AWD setup. What are the advantages, if any? I tried remove ing just the rear axle and all I do is spin. Link to comment Share on other sites More sharing options...
yangotang Posted October 8, 2009 Report Share Posted October 8, 2009 People remove it because their angle gears are failing to minimize risk to other components of the AWD system. Link to comment Share on other sites More sharing options...
DHV70 Posted October 8, 2009 Report Share Posted October 8, 2009 Don't remove the rear axle, take out the drive shaft. You've got to raise the front end, remove 3 of the 6 bolts on each end of it, the 2 bolts on the exhaust bracket, then raise the back end, spin the shaft 180 degrees, lower it and repeat. then just pull the shaft out from the back. done! Link to comment Share on other sites More sharing options...
JoshV70 Posted October 8, 2009 Report Share Posted October 8, 2009 Keep it AWD. Link to comment Share on other sites More sharing options...
sea-xc Posted October 8, 2009 Report Share Posted October 8, 2009 I pulled my driveshaft last year because I was getting a shudder on slow turns. I'm now ready to find the true cause, (cv joints and ctr bearing of driveshaft look good). If you're not having issues leave it in. Torque steer, traction control and the one wheel peel suck. I've seen no mileage benefit for those who say there is one. Link to comment Share on other sites More sharing options...
lookforjoe Posted October 8, 2009 Report Share Posted October 8, 2009 I pulled my driveshaft last year because I was getting a shudder on slow turns. I'm now ready to find the true cause, (cv joints and ctr bearing of driveshaft look good). If you're not having issues leave it in. Torque steer, traction control and the one wheel peel suck. I've seen no mileage benefit for those who say there is one. I agree, fuel economy will not really change. Remember, the AWD only sends about 20% to the rear, and only when it's needed. The extra weight of the car is really the fuel economy issue. I've been driving mine on & off for the past month w/o the AWD - and if you think the torque steer/ wheel spin is bad stock, try it w/ over 300WHP :lol: Link to comment Share on other sites More sharing options...
FCP Euro Posted October 8, 2009 Report Share Posted October 8, 2009 If you are having issues with the AWD, then pull the driver shaft. Otherwise, just leave it alone. Also, this should be moved to the repair section. Not really performance related. Link to comment Share on other sites More sharing options...
fenwick253 Posted October 8, 2009 Report Share Posted October 8, 2009 if you think the torque steer/ wheel spin is bad stock, try it w/ over 300WHP Yep... Concrete walls like FWD cars. Link to comment Share on other sites More sharing options...
sacrifice Posted October 8, 2009 Report Share Posted October 8, 2009 Any CEL with the shaft removed or is it all mechanical? Link to comment Share on other sites More sharing options...
JoshV70 Posted October 8, 2009 Report Share Posted October 8, 2009 Any CEL with the shaft removed or is it all mechanical? All mechanical on first gen AWD. Link to comment Share on other sites More sharing options...
sacrifice Posted October 8, 2009 Report Share Posted October 8, 2009 thanks. i was asking in regards to a 2000 vR Link to comment Share on other sites More sharing options...
JoshV70 Posted October 8, 2009 Report Share Posted October 8, 2009 thanks. i was asking in regards to a 2000 vR Mechanical. Link to comment Share on other sites More sharing options...
Chilled man Posted October 8, 2009 Report Share Posted October 8, 2009 AWD is for girls :lol: Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted October 9, 2009 Report Share Posted October 9, 2009 Rip that useless thing out. Link to comment Share on other sites More sharing options...
BurgerBob Posted October 9, 2009 Report Share Posted October 9, 2009 Ehh, dump it. It'll only brake with power (but I wish it wouldn't ). Link to comment Share on other sites More sharing options...
