brick8 Posted November 20, 2004 Report Share Posted November 20, 2004 I am going to try to mount a chm-6__ changer in the glove compartment of my 1995 850glt. I have an sc-811 radio. I bought a changer cable and a volalp adaptor from crutchfield. I hooked up a similar setup in my 1993 850's trunk but would like to try the glove compartment this time and would appreciate any tips you might have. Thanks! Link to comment Share on other sites More sharing options...
Adam Franke Posted November 20, 2004 Report Share Posted November 20, 2004 I have a bunch of pictures from when I did mine at http://www.goeaston.net/~lunasea/changer/. Just a warning, they are pretty big. Link to comment Share on other sites More sharing options...
Mesoam Posted November 20, 2004 Report Share Posted November 20, 2004 not sure how diff the 70/850 glove boxes are but in any case, Will put his alpine changer in his 93 glove box. Here is the thread (all the pix are gone but ask him and he might send them to you)Search results from "glove changer"Will Cd Changer Link to comment Share on other sites More sharing options...
brick8 Posted November 20, 2004 Author Report Share Posted November 20, 2004 Thanks. I got it installed. Took me about 1/2 hour extra because I got confused and plugged the old changer plug (running to the trunk area, for volvo changer that did not come with car) back in to the back of the radio instead of the new plug. DOH!!!Works great. Seems to respond quicker to the controls without the 16' cable too. I drilled a hole in the side of the glove box for the wire but didn't have to do any other mods. Just remember to remove the brackets from the changer and it fits great. Brackets not necessary because the fit is so tight anyway. Link to comment Share on other sites More sharing options...
maiku Posted November 21, 2004 Report Share Posted November 21, 2004 what i did was instead of drilling a whole, i just removed the white covering over the glove box light and threaded the cable through thereworks great and i can always retain that "stock" look if i want to remove the cd changer some time Link to comment Share on other sites More sharing options...
brick8 Posted November 21, 2004 Author Report Share Posted November 21, 2004 Wish I had thought of that, although the hole I drilled is way in back. I removed the glovebox bulb to avoid the risk of battery rundown, since I will only be using the glovebox for the cd changer now.what i did was instead of drilling a whole, i just removed the white covering over the glove box light and threaded the cable through thereworks great and i can always retain that "stock" look if i want to remove the cd changer some time← Link to comment Share on other sites More sharing options...
98BRICK Posted November 27, 2004 Report Share Posted November 27, 2004 Volvo makes a factory mounting kit for the S70 glove box...i got it for around $30 bux...now i just hafto find the right cd changer...the ones for the glove box are actually smaller.... Link to comment Share on other sites More sharing options...
