pfeener Posted November 21, 2004 Report Share Posted November 21, 2004 I have a 98 S70 with 170K miles. I have recently replaced the front sway bar links, the front struts and spring seats (the right side one was broken and was making a loud sqeaking noise), the rear shocks and shock mounts (Bilsteins Touring class all around). Replacing all these parts took care of a lot of the noises and clucks in the car, but I still have a small cluck in the rear of the car. It sounds just like the sway bar links did in the front. Are there sway bar links or joints in the back that can cause the same type noise or anything else anyone can think of? Link to comment Share on other sites More sharing options...
Staffy Posted November 21, 2004 Report Share Posted November 21, 2004 I have a 98 S70 with 170K miles. I have recently replaced the front sway bar links, the front struts and spring seats (the right side one was broken and was making a loud sqeaking noise), the rear shocks and shock mounts (Bilsteins Touring class all around). Replacing all these parts took care of a lot of the noises and clucks in the car, but I still have a small cluck in the rear of the car. It sounds just like the sway bar links did in the front. Are there sway bar links or joints in the back that can cause the same type noise or anything else anyone can think of?←I recently had this issue and it ended up being the link bars, you might want to check them. What I did was test drive.. then spray a bunch of WD40 on one link bar... test drive, then the other to isolate it.If you find it and it quiets down with the lube, it will only be quiet for about an hour or so.I have mine up on jacks right now, so in the morning when I finish up the brakes, I will take a look around to see what else might cause that noise. Link to comment Share on other sites More sharing options...
