Matty Moo Posted October 15, 2009 Report Share Posted October 15, 2009 There's an exhaust clamp that holds the downpipe into the front of the cat. Is this the same clamp that is on the backside of the cat also? I called swedish engineering (they're close) and they have a clamp for the backside, but don't list one for the front. The front one fell off yesterday. I would crawl under there and look, but she just took the car. Loud exhaust reminds me of hillbillies too much, so I need to fix it pronto. Link to comment Share on other sites More sharing options...
FCP Euro Posted October 15, 2009 Report Share Posted October 15, 2009 Are you sure there is a front clap on your 850? Do you have a stock down pipe and cat? This is what the stock cat looks like. Link to comment Share on other sites More sharing options...
Matty Moo Posted October 15, 2009 Author Report Share Posted October 15, 2009 Are you sure there is a front clap on your 850? Do you have a stock down pipe and cat? This is what the stock cat looks like. It is stock. So there isn't supposed to be a clamp there, just welded. Correct? Link to comment Share on other sites More sharing options...
FCP Euro Posted October 15, 2009 Report Share Posted October 15, 2009 It is stock. So there isn't supposed to be a clamp there, just welded. Correct? Yes, that is correct. Sounds like it is just leaking. Link to comment Share on other sites More sharing options...
Matty Moo Posted October 15, 2009 Author Report Share Posted October 15, 2009 Yes, that is correct. Sounds like it is just leaking. Yes, it is leaking. It started yesterday, could tell where it was coming from and could feel the air coming out of the joint. I'll have to look at it when she gets home. I'll weld it if it's not rotted out. Link to comment Share on other sites More sharing options...
mbsl98 Posted October 15, 2009 Report Share Posted October 15, 2009 It's not a clamp, and it's not welded, it is held with three bolts. Maybe you just need to tighten the bolts :) Link to comment Share on other sites More sharing options...
Matty Moo Posted October 15, 2009 Author Report Share Posted October 15, 2009 It's not a clamp, and it's not welded, it is held with three bolts. Maybe you just need to tighten the bolts Interesting. I'll have to check it out in a few minutes when she gets home. If the dp isn't welded to the cat, then I'm thrilled. I'd really rather tighten down 3 bolts than anything else. Link to comment Share on other sites More sharing options...
Matty Moo Posted October 15, 2009 Author Report Share Posted October 15, 2009 I found my leak. It's on the backside of the cat, and it is welded. I'll take it in and have it fixed. Link to comment Share on other sites More sharing options...
Cal3thousand Posted October 16, 2009 Report Share Posted October 16, 2009 I found my leak. It's on the backside of the cat, and it is welded. I'll take it in and have it fixed. I think mbsl98 was mistakenly referring to the three bolts that hold the DP to the manifold while you were referring to the cat and the DP/piping. Link to comment Share on other sites More sharing options...
Matty Moo Posted October 16, 2009 Author Report Share Posted October 16, 2009 I think mbsl98 was mistakenly referring to the three bolts that hold the DP to the manifold while you were referring to the cat and the DP/piping. I figured that after crawling under there. I've never paid much attention to the exhaust on either of my 850's as neither of them showed any real signs of corrosion. pretty impressive for a 13 year old car that has spent it's life in the salty midwest. Link to comment Share on other sites More sharing options...
