twistab4pudd Posted October 17, 2009 Report Share Posted October 17, 2009 Hello all, I bought the BluePower BLP-890 and I just finished installing it, but now my rear defrost, and heated seat controls, on the climate control panel do not work. When I use the heat or defrost, the right side of the car blows cold air now. I wasn't sure why this was happening, so I checked all fuses and relays, they were all fine. I even went out and looked for a new climate control panel, found one and spent nearly a $100 on it, and it did not fix the problem. I'm not sure what to do, has anyone heard of this problem? Please, if anyone can help, it is already in the 40's in Chicago, and half my car has heat, and the rear defrost does not currently work. Thanks so much in advance, Brian P.S. I don't really want to go back to the stock unit. Link to comment Share on other sites More sharing options...
MyCarIsRed Posted October 17, 2009 Report Share Posted October 17, 2009 Hello all, I bought the BluePower BLP-890 and I just finished installing it, but now my rear defrost, and heated seat controls, on the climate control panel do not work. When I use the heat or defrost, the right side of the car blows cold air now. I wasn't sure why this was happening, so I checked all fuses and relays, they were all fine. I even went out and looked for a new climate control panel, found one and spent nearly a $100 on it, and it did not fix the problem. I'm not sure what to do, has anyone heard of this problem? Please, if anyone can help, it is already in the 40's in Chicago, and half my car has heat, and the rear defrost does not currently work. Thanks so much in advance, Brian P.S. I don't really want to go back to the stock unit. My guess is you unplugged or loosened some other connection, causing the rear defrost and seat heaters to not work, and maybe damaged a damper underneath screwing up the right side. No flashing lights or errors? Link to comment Share on other sites More sharing options...
