johnloves850's Posted October 18, 2009 Report Share Posted October 18, 2009 I am not sure of a good ground for my 854.. I grounded this same amp perfectly in my wagon, but the sedan does not have the bolt that I am looking for. I was thinking about using the rear side bolster clip/pin thing? It is a screw with a 40 torx end. When it is removed, it is what seems to be the chassis underneath, a little paint just needs to be scraped off. Any suggestions? Or better ground locations? Thanks, John Link to comment Share on other sites More sharing options...
Che'_Moderator Posted October 18, 2009 Report Share Posted October 18, 2009 If you look where the factory CD changer is you will see a metal shelf right behind the wheel well thats part of the unibody. Its like 12ga steel. Sand the paint and primer off it and ground away. My battery is grounded there and has no problem pushing this: Link to comment Share on other sites More sharing options...
