BlackBeast Posted October 18, 2009 Report Share Posted October 18, 2009 Anyone have any experience of the SRT4 3" Sports Cat from ATP on their T5/R? http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TP&Product_Code=ATP-VSRT-003&Category_Code= Link to comment Share on other sites More sharing options...
7 VII 7 Posted October 18, 2009 Report Share Posted October 18, 2009 Anyone have any experience of the SRT4 3" Sports Cat from ATP on their T5/R? http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TP&Product_Code=ATP-VSRT-003&Category_Code= I would not waste the money on this... just get a HIGH FLOW Magnaflow CAT for uner $100 Link to comment Share on other sites More sharing options...
rbodor3 Posted October 19, 2009 Report Share Posted October 19, 2009 not sure if you thought of this but if you do go with that cat you either need to cut off the flanges to weld together into 3" pipe or weld on vband flanges into your exhaust to replace. Link to comment Share on other sites More sharing options...
BlackBeast Posted October 19, 2009 Author Report Share Posted October 19, 2009 I would not waste the money on this... just get a HIGH FLOW Magnaflow CAT for uner $100 Found out off ATP themselves that it is a Magnaflow ceramic cat with the flanges welded on. I dont know if its a 100cel cat though. not sure if you thought of this but if you do go with that cat you either need to cut off the flanges to weld together into 3" pipe or weld on vband flanges into your exhaust to replace. I am getting a 3" turbo back system made once all the other modifications have been fitted (built engine, GT3071r etc etc), ATP also sell a decat of the same length with the vband flanges so i can swap them out for the MOT test here in the UK. Unsure if I want to go this route yet though or permanently use a sports cat. Link to comment Share on other sites More sharing options...
rbodor3 Posted October 19, 2009 Report Share Posted October 19, 2009 I would go with a permanent cat, but no idea how strict MOT is over there. Only reason I say permanent is the extra cost - besides the extra cost in material for the VBands (which are rip-off expensive for no legit reason) it sounds like you're also going to be paying a guy to make 4 extra welds, simply to be able to remove the cat. Link to comment Share on other sites More sharing options...
Ipd Posted October 19, 2009 Report Share Posted October 19, 2009 Besides, those maganflow cats don't last all that long for higher HP cars. Stage I/II cars tend to do better with them. Mine made it 8 mos before it croaked. The biscuit that is the catalyst is only about 4 to 5 inches long, not a lot of material there. Might need to check out Kemira, they have twin catalyst designs that can handle the kind of through put you're talking about. At 12:1 AFR and 300+ bhp the amount of exhaust gas going through that cat is almost twice what it was designed to handle according to the data sheets I've seen. So longevity is not surprising really. Link to comment Share on other sites More sharing options...
gdizzle Posted October 19, 2009 Report Share Posted October 19, 2009 Besides, those maganflow cats don't last all that long for higher HP cars. Stage I/II cars tend to do better with them. Mine made it 8 mos before it croaked. The biscuit that is the catalyst is only about 4 to 5 inches long, not a lot of material there. Might need to check out Kemira, they have twin catalyst designs that can handle the kind of through put you're talking about. At 12:1 AFR and 300+ bhp the amount of exhaust gas going through that cat is almost twice what it was designed to handle according to the data sheets I've seen. So longevity is not surprising really. Exactly. :tup: Link to comment Share on other sites More sharing options...
TyConn Posted October 20, 2009 Report Share Posted October 20, 2009 lucky you got a +1 for that one, so true Link to comment Share on other sites More sharing options...
Ipd Posted October 20, 2009 Report Share Posted October 20, 2009 OOOOooh I feel a bromance coming on! Link to comment Share on other sites More sharing options...
BlackBeast Posted October 20, 2009 Author Report Share Posted October 20, 2009 Thanks Lucky. If I went down the ATP route the only time the cat would be fitted would be for the MOT, it would have the decat on for the rest of the time. Where can I source kemira cats from? Link to comment Share on other sites More sharing options...
Ipd Posted October 20, 2009 Report Share Posted October 20, 2009 http://www.kemira.com/en/media/pressreleases/Pages/KemiraMetalkatOyhasbecomeEcocatOy.aspx Click on contact us and then choose a location close to you... Link to comment Share on other sites More sharing options...
