rbodor3 Posted October 21, 2009 Report Share Posted October 21, 2009 I know this was asked, and somebody even started compiling a list of which injectors came stock in which cars, but can't seem to locate it. Couldn't have been more than a month or two ago...? Fact - I have stock orange injectors in my 01 S60 2.4T I called up the local scrap looking for blues/greens, which the guy reported he found the following: 04 S60 (nonturbo) = greens 02 S60 (nonturbo) = blues Is this right? Same price for both but will probably go with the greens due to newer age and 465 vs. 395cc capacity. Link to comment Share on other sites More sharing options...
Wille Posted October 21, 2009 Report Share Posted October 21, 2009 The greens (465cc@3.8bar) you are looking for can only be found stock in R-models 2003-> and the blue (395cc@3.8bar) ones in 2001-2004 T5 models. Nonturbo green and blue injectors is someting compleatly different. Link to comment Share on other sites More sharing options...
Wille Posted October 21, 2009 Report Share Posted October 21, 2009 Orange 315cc@3.8bar Bosch# 0280150785 Blue 395cc@3.8bar Bosch# 0280155830 Green 465cc@3.8bar Bosch# 0280150968 Link to comment Share on other sites More sharing options...
rbodor3 Posted October 21, 2009 Author Report Share Posted October 21, 2009 That's what I thought, I wasn't aware that volvo put on stock same color top injectors with completely different flow amounts, especially on the naturally aspirated engines. Link to comment Share on other sites More sharing options...
MFlowT5 Posted October 21, 2009 Report Share Posted October 21, 2009 I believe my car has blue injectors. What are the HP benefits of the green injectors? Link to comment Share on other sites More sharing options...
Mogatu'r Posted October 21, 2009 Report Share Posted October 21, 2009 green injectors can also be found on '99 and '00 V70R's... Link to comment Share on other sites More sharing options...
rbodor3 Posted October 21, 2009 Author Report Share Posted October 21, 2009 I believe my car has blue injectors. What are the HP benefits of the green injectors? blue injectors nominal flow 395cc green injectors 465cc Link to comment Share on other sites More sharing options...
Big Will Posted October 21, 2009 Report Share Posted October 21, 2009 Keep in mind that these numbers are at 3.8 bar for FP. Blues can also be found on 99 and 2000 T5s. Link to comment Share on other sites More sharing options...
Wille Posted October 21, 2009 Report Share Posted October 21, 2009 I believe my car has blue injectors. What are the HP benefits of the green injectors? Non if the flow of your current injectors are enough for the tune you are running. Looking at your mod list greens would probably be a good update for you along with a new software. Here in Europe stage 3 for the 2005 S60T5 includs the greens along with DP, Cat-Back and airfilter of which the injectors seems to be the only piece you are lacking at the moment. green injectors can also be found on '99 and '00 V70R's... Keep in mind that these numbers are at 3.8 bar for FP. Blues can also be found on 99 and 2000 T5s. True, this should be right: Volvo T5 99-> Blue 395cc@3.8bar Bosch# 0280155830 Volvo V70R 00, S60R/V70R 03-> Green 465cc@3.8bar Bosch# 0280150968 Link to comment Share on other sites More sharing options...
Big Will Posted October 21, 2009 Report Share Posted October 21, 2009 His car is an LPT not an HPT but I agree that greens and a proper tune to match would benefit that 19T. Injectors are probably the limiting factor at the moment. Link to comment Share on other sites More sharing options...
yangotang Posted October 21, 2009 Report Share Posted October 21, 2009 I know this was asked, and somebody even started compiling a list of which injectors came stock in which cars, but can't seem to locate it. Couldn't have been more than a month or two ago...? Fact - I have stock orange injectors in my 01 S60 2.4T I called up the local scrap looking for blues/greens, which the guy reported he found the following: 04 S60 (nonturbo) = greens 02 S60 (nonturbo) = blues Is this right? Same price for both but will probably go with the greens due to newer age and 465 vs. 395cc capacity. IIRC the 99+ N/A cars i've seen have denso blue injectors, but they aren't physically the same as the blue injectors which you find on turbo cars. The denso NA injectors have 1" diameter, while the turbo blues have .5" diameter injectors. I'm not sure if they are the same or not, but I will guess not. It would be kind of silly to see a NA car have injectors that big. Link to comment Share on other sites More sharing options...
L8 APEKS Posted October 21, 2009 Report Share Posted October 21, 2009 That's what I thought, I wasn't aware that volvo put on stock same color top injectors with completely different flow amounts, especially on the naturally aspirated engines. Always better to use the part number instead of the color for this very reason! ;) Link to comment Share on other sites More sharing options...
Wille Posted October 22, 2009 Report Share Posted October 22, 2009 His car is an LPT not an HPT but I agree that greens and a proper tune to match would benefit that 19T. Injectors are probably the limiting factor at the moment. The OPs car is indeed a LPT but MFlowT5s car which I was referring to is a HPT. Link to comment Share on other sites More sharing options...
rbodor3 Posted October 22, 2009 Author Report Share Posted October 22, 2009 IIRC the 99+ N/A cars i've seen have denso blue injectors, but they aren't physically the same as the blue injectors which you find on turbo cars. The denso NA injectors have 1" diameter, while the turbo blues have .5" diameter injectors. I'm not sure if they are the same or not, but I will guess not. It would be kind of silly to see a NA car have injectors that big. That makes a lot of sense, and I believe that is the situation. Link to comment Share on other sites More sharing options...
lookforjoe Posted October 22, 2009 Report Share Posted October 22, 2009 Always better to use the part number instead of the color for this very reason! Absolutely! Get the Bosch or Volvo # off the injector, and google it - easy enough! Greens (468cc) will go nicely with the 19T - as long as your tune can allow for them, otherwise, there's no point. Link to comment Share on other sites More sharing options...
