Olive850 Posted October 21, 2009 Report Share Posted October 21, 2009 hey whats going on? so i have a 1998 volvo s70 n/a, auto. 130K. i was driving to school today and i was going about 70mph and i noticed that the yellow arrow was flashing, so of course my heart skipped a beat. i looked at the rpms it was about 2500 maybe a little higher. i experienced this before in my 850, but the flashing light would go away, and just a check engine woudl stay, but now the light just flashes. the car shifts perfectly and rpms are normal, so is this just a pnp switch or should i worry? thanks Link to comment Share on other sites More sharing options...
JordanW Posted October 21, 2009 Report Share Posted October 21, 2009 Check trans fluid level and condition have codes pulled if possible. Link to comment Share on other sites More sharing options...
Olive850 Posted October 21, 2009 Author Report Share Posted October 21, 2009 Check trans fluid level and condition have codes pulled if possible. fluid levels are good, if it was a serious issue, wouldnt i have noticed a change in the way it shifts and drives?? Link to comment Share on other sites More sharing options...
JordanW Posted October 21, 2009 Report Share Posted October 21, 2009 Worry and be scared to drive it.... No, I don't think you'll drop the trans on the road. But, get it checked out. Could be as simple as a PNP, could be fluid temp was too high, could be many things. Don't drive around with the flashing arrow though, obviously something is up. Did you check the trans fluid with the engine running and warm? What color was the trans fluid? Has it been changed recently? I'd still get the codes pulled if you can... You could try seeing if there are any OBDII codes, though it may be just a TCM DTC. Link to comment Share on other sites More sharing options...
shreksbrother Posted October 21, 2009 Report Share Posted October 21, 2009 +1 on PNP switch. My car has been doing the exact same thing since I bought it a month and about 2k miles ago. Haven't gotten around to changing the switch yet. I would try the maneuver of moving your shift lever quickly from P-1 quickly 15-20 times. Stops mine from flashing for a day or two, and helps reaffirm that's all that's wrong. Link to comment Share on other sites More sharing options...
Olive850 Posted October 21, 2009 Author Report Share Posted October 21, 2009 +1 on PNP switch. My car has been doing the exact same thing since I bought it a month and about 2k miles ago. Haven't gotten around to changing the switch yet. I would try the maneuver of moving your shift lever quickly from P-1 quickly 15-20 times. Stops mine from flashing for a day or two, and helps reaffirm that's all that's wrong. so your light flashes while ur driviing Link to comment Share on other sites More sharing options...
shreksbrother Posted October 21, 2009 Report Share Posted October 21, 2009 so your light flashes while ur driviing Absolutely. Same symptoms you describe. Perfect transmission operation, yellow upshift light and alternating "E" and "W" lights flashing while driving. Try the gear selector thing. If it stops for a bit (heck, even if it doesn't), it's your PNP switch. Link to comment Share on other sites More sharing options...
Olive850 Posted October 22, 2009 Author Report Share Posted October 22, 2009 Absolutely. Same symptoms you describe. Perfect transmission operation, yellow upshift light and alternating "E" and "W" lights flashing while driving. Try the gear selector thing. If it stops for a bit (heck, even if it doesn't), it's your PNP switch. yes exactly the same, so i have a question i have a spare pnp switch from a1995 volvo, the connections dont seem to fit, different size pins, did they switch them up in 1998 ?? Link to comment Share on other sites More sharing options...
v4lve Posted October 22, 2009 Report Share Posted October 22, 2009 If you don't have reverse lights it is a pretty good indicator of a neutral safety switch(pnp). As mentioned before, run/slide through the gears (while stationary obviously) back and forth 15-20 times. Might get lucky and have that clean the contacts and buy you a little more time. Link to comment Share on other sites More sharing options...
Olive850 Posted October 22, 2009 Author Report Share Posted October 22, 2009 If you don't have reverse lights it is a pretty good indicator of a neutral safety switch(pnp). As mentioned before, run/slide through the gears (while stationary obviously) back and forth 15-20 times. Might get lucky and have that clean the contacts and buy you a little more time. So today I attempted to put in a spare pnp switch and the plugs did not fit, so I put everything back and so far today no flashing light at all. Its weird though my reverse light did not seem to be affected when the light was flashing Link to comment Share on other sites More sharing options...
v4lve Posted October 22, 2009 Report Share Posted October 22, 2009 what did the spare come out of Link to comment Share on other sites More sharing options...
Olive850 Posted October 22, 2009 Author Report Share Posted October 22, 2009 what did the spare come out of 95 850 the pins were different what did the spare come out of 95 850 the pins were different Link to comment Share on other sites More sharing options...
v4lve Posted October 22, 2009 Report Share Posted October 22, 2009 if you're somewhat local you can swing by and pick up the one i hacked out of my 96, other than that i think it's like $85-100 from fcp Link to comment Share on other sites More sharing options...
pcguru000 Posted October 23, 2009 Report Share Posted October 23, 2009 When my up arrow light was flashing i prayed it was a pnp but a couple days later i was leaving shop after paying 1300 bucks and getting a new trans.. Apparently the previous owner had some sort of obsession with neutral dropping it at the redline... never the less i would expect yours hasn't been through such hell- a pnp switch seems likely Also- did you check not only trans fluid level but color? smell? - bad tranny fluid is brown and will likely smell burnt and nasty - good should be pink and have not smell like much at all. A flush is always good too- when you (or whomever does it) goes to pull the plug off the bottom of the tranny to do the drain- check the inside of the plug and see if there is any build up of metal... we got like and inch worth of metal shards before we got any fluid out of my tranny LOL Link to comment Share on other sites More sharing options...
