HPTDoh Posted October 24, 2009 Report Share Posted October 24, 2009 After inspecting all my vacuum lines and re-securing the wastegate arm, I was still experiencing a boost leak. Today I finally got around to replacing the BCS with a MBC. I turned it all the way down and went for a spin. Awesome! It boosts slowly up to about 10 psi... problem solved, right?. Apparently not because when I start to turn it up, boost climbs super slowly and maxes out at about 5 psi. This starts at about a quarter turn up from the bottom. Did I install it wrong? Seems pretty straightforward.. Link to comment Share on other sites More sharing options...
excessive101 Posted October 24, 2009 Report Share Posted October 24, 2009 did you try to turn it back down? what mbc is it..? if it's a cheap one, you may need to get a stiffer spring.. or try and stretch the spring.. i've heard it helps.. Link to comment Share on other sites More sharing options...
HPTDoh Posted October 24, 2009 Author Report Share Posted October 24, 2009 did you try to turn it back down? what mbc is it..? if it's a cheap one, you may need to get a stiffer spring.. or try and stretch the spring.. i've heard it helps.. Yes, I left it all the way down just because I get the best performance out of it that way. It is a $20 ebay style one. Should I try stretching the spring before a new one? Where can you even get a stiffer spring? Link to comment Share on other sites More sharing options...
excessive101 Posted October 24, 2009 Report Share Posted October 24, 2009 an Ace hardware or someplace like that would have it.. and the "stretching the spring" was done to an ebay mbc, so worth a shot.. Link to comment Share on other sites More sharing options...
ean carr Posted October 24, 2009 Report Share Posted October 24, 2009 yeah try stretching the spring, I tried a cheap MBC and had the same problem. Link to comment Share on other sites More sharing options...
MyCarIsRed Posted October 25, 2009 Report Share Posted October 25, 2009 Pen springs can work too. Link to comment Share on other sites More sharing options...
L8 APEKS Posted October 25, 2009 Report Share Posted October 25, 2009 It is a $20 ebay style one. Spending another $20-$40 for a decent one would have meant you wouldn't have had to make this post and you would be done troubleshooting. I'd say splurge on a Hallman, but that's just me. Never had a single boost spike, nor any boost fade on my 940. It was rock solid for 4 years til I sold the car. Well worth the 70 I spent on it! But if that's not an option...go to the hardware store and get some different springs. Spend a day mixing, matching, testing, and tuning. Hopefully that will work for you! Link to comment Share on other sites More sharing options...
HPTDoh Posted October 25, 2009 Author Report Share Posted October 25, 2009 Spending another $20-$40 for a decent one would have meant you wouldn't have had to make this post and you would be done troubleshooting. I'd say splurge on a Hallman, but that's just me. Never had a single boost spike, nor any boost fade on my 940. It was rock solid for 4 years til I sold the car. Well worth the 70 I spent on it! But if that's not an option...go to the hardware store and get some different springs. Spend a day mixing, matching, testing, and tuning. Hopefully that will work for you! bleh.. I usually spring for the tried and true parts. But for this, I figured so many people use an ebay mbc, I couldn't go wrong. How do I even go about dissembling it? Screw it towards the + til it falls apart? Link to comment Share on other sites More sharing options...
pcguru000 Posted October 25, 2009 Report Share Posted October 25, 2009 Do you have a bleed? does the mbc have one or do you need one installed within the line? I with the homedepot mbc i made just adding a T in the line and then crimping the T part a good bit made all the difference in how the mbc worked.. Link to comment Share on other sites More sharing options...
sconeman Posted October 25, 2009 Report Share Posted October 25, 2009 bleh.. I usually spring for the tried and true parts. But for this, I figured so many people use an ebay mbc, I couldn't go wrong. How do I even go about dissembling it? Screw it towards the + til it falls apart? just a thought..you might need some thread tape on that sucka Link to comment Share on other sites More sharing options...
HPTDoh Posted October 26, 2009 Author Report Share Posted October 26, 2009 Do you have a bleed? does the mbc have one or do you need one installed within the line? I with the homedepot mbc i made just adding a T in the line and then crimping the T part a good bit made all the difference in how the mbc worked.. I don't have a bleed. It did come with a T, though.. I don't really understand how this is supposed to work. Any pics? Does it go on the wastegate side or the turbo inlet side? just a thought..you might need some thread tape on that sucka I did intend to, but forgot. But it holds boost pretty well under the stock boost level, so I'm not sure that's the problem. Link to comment Share on other sites More sharing options...
