SALESMANJOE Posted November 2, 2009 Report Share Posted November 2, 2009 I have a Volvo 850 turbo looking at that only has 130k but compression is 130-130-130-130-130 that just seems low to me but it is even acrossthe board. I just thought it should be like 145 or 150 thanks joe Link to comment Share on other sites More sharing options...
jnderr Posted November 2, 2009 Report Share Posted November 2, 2009 I have a Volvo 850 turbo looking at that only has 130k but compression is 130-130-130-130-130 that just seems low to me but it is even acrossthe board. I just thought it should be like 145 or 150 thanks joe Do a leakdown test, compression is even across the board so thats a pretty healthy sign, I'd be more concerned if there was a lot of variance. Link to comment Share on other sites More sharing options...
bergmjs Posted November 2, 2009 Report Share Posted November 2, 2009 Healthy compression for the turbo model is 156-189 psi. Link to comment Share on other sites More sharing options...
Oreo931 Posted November 2, 2009 Report Share Posted November 2, 2009 Do a leakdown test, compression is even across the board so thats a pretty healthy sign, I'd be more concerned if there was a lot of variance. Anything below 140 warrants a rebuild IIRC. If not, I know that 130 is pretty low. I would personally pass on the car. If you want to buy it though, a leakdown test would be the best next step. Was the engine warmed up when you did the compression test? Edit: Stock compression on an 850 Turbo is ~180psi. Link to comment Share on other sites More sharing options...
SALESMANJOE Posted November 2, 2009 Author Report Share Posted November 2, 2009 good replys, yes engine was warm when doing the coompression test. What i did is had engine warm then pulled all the plugs, unhooked the coil, and started from cylinder one to cyclinder 5 cranking each cyclinder for a 5 count checked it twice too for compression. I was just worried when i say it was only 130 Link to comment Share on other sites More sharing options...
FCP Euro Posted November 2, 2009 Report Share Posted November 2, 2009 130 is very low for an engine with only 130K miles on it. My 850 T5 has about 150 across the board and it has 195K on it. Link to comment Share on other sites More sharing options...
Oreo931 Posted November 2, 2009 Report Share Posted November 2, 2009 good replys, yes engine was warm when doing the coompression test. What i did is had engine warm then pulled all the plugs, unhooked the coil, and started from cylinder one to cyclinder 5 cranking each cyclinder for a 5 count checked it twice too for compression. I was just worried when i say it was only 130 Next time pull the fuel pump fuse as well so you remove the risk of starting a fire. Link to comment Share on other sites More sharing options...
bum2kev Posted November 2, 2009 Report Share Posted November 2, 2009 did you open the throttle all the way? Link to comment Share on other sites More sharing options...
bergmjs Posted November 2, 2009 Report Share Posted November 2, 2009 You can turn it over more than 5 times if the gauge keeps going up. I keep it cranking until the gauge arrives at a steady value. Link to comment Share on other sites More sharing options...
