washdup Posted November 3, 2009 Report Share Posted November 3, 2009 Pulled and opened my 816 to replace a bulb, then put everything back together and reinstalled the HU. Radio works, amp works, but now I get EEEEE when I press the CHGR button, which used to activate the iPod via the USA-Spec interface thingamajig. I double-checked the external cable connections and looks good. Didn't take the HU apart again tho. Ideas/suggestions, please. Link to comment Share on other sites More sharing options...
yangotang Posted November 3, 2009 Report Share Posted November 3, 2009 EEEE means disconnected, usually. did you check to make sure your usaspec was still working? did you make sure that only the passenger side of the BBK was installed and not the driver's side? Link to comment Share on other sites More sharing options...
washdup Posted November 3, 2009 Author Report Share Posted November 3, 2009 EEEE means disconnected, usually. did you check to make sure your usaspec was still working? did you make sure that only the passenger side of the BBK was installed and not the driver's side? Yeah, the question is *what* is disconnected. Like I said, the cables look good. The USA spec has no switch or light on it to see if it's working. But the iPod is staying dark, so there's no connection for sure. What about that ribbon thingy inside the HU? Could that be disconnected? I'd think there'd be no radio either, tho. BBK = :lol: SOLD! Link to comment Share on other sites More sharing options...
beadgc23 Posted November 3, 2009 Report Share Posted November 3, 2009 The USA•SPEC will charge the iPod even if the HU is off, so if you're not seeing the battery charging icon on the iPod my first guess is that it's not getting power. Check the 12V & ACC leads to see if they're well connected - scotchloc tap-ins can work loose - and spray some electronic cleaner into the big multipin DIN style connectors (power off first!) Yeah, the question is *what* is disconnected. Like I said, the cables look good. The USA spec has no switch or light on it to see if it's working. But the iPod is staying dark, so there's no connection for sure. What about that ribbon thingy inside the HU? Could that be disconnected? I'd think there'd be no radio either, tho. The USA•SPEC adapter has a small +12V connector for accessory power - if it's "on" then that will be active. Check it with a meter. Link to comment Share on other sites More sharing options...
washdup Posted November 3, 2009 Author Report Share Posted November 3, 2009 I'm wondering if something internal to the HU, since all I did with the USA spec was disconnect it at the HU and then reconnect it. :huh: Link to comment Share on other sites More sharing options...
beadgc23 Posted November 3, 2009 Report Share Posted November 3, 2009 Lets take it step by step - is your iPod charging? Link to comment Share on other sites More sharing options...
washdup Posted November 3, 2009 Author Report Share Posted November 3, 2009 Lets take it step by step - is your iPod charging? It's dark with the stereo on now, so no. Link to comment Share on other sites More sharing options...
beadgc23 Posted November 4, 2009 Report Share Posted November 4, 2009 It's dark with the stereo on now, so no. Right - so no power to the USA•SPEC. You've got 2 cables on the CPB-VOL cable (which is what you ought to have for sc-xxx compatibility), red & yellow. Red for the ACC power, yellow for BATT (constant 12V) I'd get new crimp connectors (or better, solder them on to the lines to the HU) It's possible that the cable has failed internally or at the multipin connector, so use contact cleaner. In any case, double check this cable and the ipod cable too for bent pins etc. If you have a multimeter, you could check the accessory power connector on the white interface box to verify. Hope this helps! NB - I'll bet there's nothing wrong with the 816! I'm wondering if something internal to the HU, since all I did with the USA spec was disconnect it at the HU and then reconnect it. ...and stressed the power connections to the interface by removing the HU. Ask me how I know blah blah Where did you tap in to get +12V & ACC? Link to comment Share on other sites More sharing options...
washdup Posted November 4, 2009 Author Report Share Posted November 4, 2009 I did not check those connections. Good call. I did solder them, but with all the removal and install the HU gets with bulbs going out intermittently, that could very well be the issue. Will report back, probably after the weekend when I can do this in broad daylight. Link to comment Share on other sites More sharing options...
washdup Posted November 4, 2009 Author Report Share Posted November 4, 2009 CORRECTION: I double-checked and the iPod IS activated with the car on, so it is receiving power. Still getting the EEEEE message upon pushing the CHGR button. Link to comment Share on other sites More sharing options...
washdup Posted November 7, 2009 Author Report Share Posted November 7, 2009 I pulled the HU today and checked the yellow and red connections. I re-soldered the yellow, as it looked a bit loose. Removed the front panel of the HU and made sure the ribbon was snug. Double-checked the connections at iPod, USA box, and then reconnected everything. Still EEEEE. I don't think it would be the red or yellow wires, since those are power, and the iPod is charging when the car's power is on. I'd hate to pay to have a stereo shop to troubleshoot it, but I'm really starting to miss my songlist. Link to comment Share on other sites More sharing options...
beadgc23 Posted November 7, 2009 Report Share Posted November 7, 2009 Think you could use another HU to check yours against. Do you have access to one? NB You could probably buy another 816 for less than an hour's bench time at an audio shop. Link to comment Share on other sites More sharing options...
washdup Posted November 8, 2009 Author Report Share Posted November 8, 2009 That's a great idea, but wouldn't the USA Spec have to be wired in to do an adequate test? Link to comment Share on other sites More sharing options...
beadgc23 Posted November 8, 2009 Report Share Posted November 8, 2009 That's a great idea, but wouldn't the USA Spec have to be wired in to do an adequate test? I'm thinking...try another HU with the existing cables. That is , plug your USA•SPEC into another HU changer port. I have one lying around in decent shape, I replaced the bulbs (without issues) and then went to a 901. As an aside, a 901 & amp is a huge improvement over the 816... Link to comment Share on other sites More sharing options...
washdup Posted November 8, 2009 Author Report Share Posted November 8, 2009 I have a T5 (40w) amp in now, and it did help the poor SC816 quite a bit. My '04 had a very nice HU in it. Can't remember what the number was. It had dolby and center channel. 4-disk. Ok, back to topic. Do you think the test would work even without a power source? Link to comment Share on other sites More sharing options...
