Pops Racer Posted November 18, 2009 Report Share Posted November 18, 2009 I'm looking for a OBD probe with wire. Mine broke at the probe part and there is not enough wire to even think about soldering it back on. Donkeychains Link to comment Share on other sites More sharing options...
mdlimy Posted November 18, 2009 Report Share Posted November 18, 2009 I'm looking for a OBD probe with wire. Mine broke at the probe part and there is not enough wire to even think about soldering it back on. Donkeychains as in the plug with the pigtail wiring harness? i have one from a 00 v70r, doubt that would work but i suppose one could make it work. Link to comment Share on other sites More sharing options...
Ipd Posted November 18, 2009 Report Share Posted November 18, 2009 If OP doesn't take it I will. Converting my 94 to use the OBDII port so I can use datalogger, scangauge, etc.... Thanks. Link to comment Share on other sites More sharing options...
mdlimy Posted November 19, 2009 Report Share Posted November 19, 2009 If OP doesn't take it I will. Converting my 94 to use the OBDII port so I can use datalogger, scangauge, etc.... Thanks. wingnut shoot me a pm if you want it or not, ill forget to check this thread :lol: Link to comment Share on other sites More sharing options...
Pops Racer Posted November 19, 2009 Author Report Share Posted November 19, 2009 as in the plug with the pigtail wiring harness? i have one from a 00 v70r, doubt that would work but i suppose one could make it work. It's like the one on your 855 code reader under the hood. A single wire with a little probe on the end. All I need to do is splice the wire with the probe on it to my existing wire "stub" and away I go. Prolly not the same part as a 2000. Hope I'm not making a mistake in my description. Wish I had a pic. Link to comment Share on other sites More sharing options...
mdlimy Posted November 20, 2009 Report Share Posted November 20, 2009 ah your looking for an obd1 test port, i mistaked you for obd2 port. Link to comment Share on other sites More sharing options...
Pops Racer Posted November 20, 2009 Author Report Share Posted November 20, 2009 ah your looking for an obd1 test port, i mistaked you for obd2 port. It's the test jumper for the dtc reader under the hood, OBDI, sorry. Link to comment Share on other sites More sharing options...
