Flukey Posted November 23, 2009 Report Share Posted November 23, 2009 I dont know crap about the V40. A poor lady I work with has one with a engine vibration around 1000 to 1200 rpms. You can lightly modulate the throttle at that point and it vibrates like its running on meth anphetimines. This thing has 90,000 on the clock. She bought it used with 50 grand on it and she says it always did it. I would like to help her out. Does anybody have ideas,or is someone familiar with this issue? This lady drives this dented up POS 40 miles to work each day and already broke a ball joint one day and had to get towed and subsequently robbed to fix it by most likely some butcher. I just want to give her some useful advice. Anybody have this issue with their V40? Thanks in advance. Flukey Link to comment Share on other sites More sharing options...
mdlimy Posted November 23, 2009 Report Share Posted November 23, 2009 I dont know crap about the V40. A poor lady I work with has one with a engine vibration around 1000 to 1200 rpms. You can lightly modulate the throttle at that point and it vibrates like its running on meth anphetimines. This thing has 90,000 on the clock. She bought it used with 50 grand on it and she says it always did it. I would like to help her out. Does anybody have ideas,or is someone familiar with this issue? This lady drives this dented up POS 40 miles to work each day and already broke a ball joint one day and had to get towed and subsequently robbed to fix it by most likely some butcher. I just want to give her some useful advice. Anybody have this issue with their V40? Thanks in advance. Flukey motor mounts, most likely the front and/or rear lower mounts. Link to comment Share on other sites More sharing options...
Flukey Posted November 23, 2009 Author Report Share Posted November 23, 2009 motor mounts, most likely the front and/or rear lower mounts. I am kinda thinking the same thing. But why does it vibrate only at a certain rpm? If it is mounts ya would get clunk noise with engagement and aceleration cause the engine wants to move when it is under a load. Has anybody experienced a harmonec balancer going bad or a welded weight on the torque converter coming off to cause this vibration? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted November 23, 2009 Report Share Posted November 23, 2009 +1 on the engine mounts. It could be all 4 gone bad, they can cause weird vibrations. Don't forget about the one under the air box. Link to comment Share on other sites More sharing options...
mdlimy Posted November 23, 2009 Report Share Posted November 23, 2009 Has anybody experienced a harmonec balancer going bad or a welded weight on the torque converter coming off to cause this vibration? your overthinking it, bad motor mounts will cause more vibration at certain rpms than others. its possible its missfiring i suppose, how does it run? CEL? Link to comment Share on other sites More sharing options...
Flukey Posted November 24, 2009 Author Report Share Posted November 24, 2009 your overthinking it, bad motor mounts will cause more vibration at certain rpms than others. its possible its missfiring i suppose, how does it run? CEL? No mis-fire and no cel. Runs decent. I tell her to take it to the dealer and have the mounts checked out. Thanks for the replys guys. Link to comment Share on other sites More sharing options...
theForgottenone Posted December 1, 2009 Report Share Posted December 1, 2009 No mis-fire and no cel. Runs decent. I tell her to take it to the dealer and have the mounts checked out. Thanks for the replys guys. Telling her go take it to the dealer is just like straight up anal-rape for her. Want to save some money, tell her to find an Swedish independent shop. And yes, those motor mounts need to be replace. There are 4 of them all together. Link to comment Share on other sites More sharing options...
MrWinkey Posted December 3, 2009 Report Share Posted December 3, 2009 Telling her go take it to the dealer is just like straight up anal-rape for her. Now that's not nice! Start with the front upper mount on the passenger side frame rail. Link to comment Share on other sites More sharing options...
loseR99 Posted December 5, 2009 Report Share Posted December 5, 2009 S40 motor mount replacement Link to comment Share on other sites More sharing options...
