HeavyIron Posted November 29, 2009 Report Share Posted November 29, 2009 MAJOR PRICE REVISION!!!! $12000 firm with $500.00 Paypal deposit to be refunded at sale completion for final price of $11500.00!!!!! This is a mind blowing deal on an amazing car. I can also arrange pickup from Omaha, NE airport or help arrange truck freight if needed. I am in anguish as I type this, yet I know it has to be done. At the beginning of my build in April as my wife handed me over the checkbook She made me promise that I would not let this car drag our family down. fast forward 8 months and almost $14k later and our situation has changed - so this is me keeping my promise. The car will have its last bugs worked out before being sold, but will need a new home by the end of the year. I hope and pray it will go to someone who has the same passion for it as I have had. Here is a list of things that I have done since I purchased the car. Purchased 06/23/07 from Swedish Car Specialists in Schaumburg, IL with 73K on the odometer. Incl. SCS I am the 3rd owner. Car currently has 95, 4xx miles on it. Suspension: Koni adjustables on all four corners. H&R coil Springs FCP groton Spring seats - I know I know - New IPD HD spring seats are included, but not installed IPD HD endlinks IPD sway bars F & R 25/22mm IPD Strut tower brace (new aluminum one- not cherry turbo one) New lower control arms & ball joints -10k ago New outer tie rods - 10k ago Mounts: IPD Poly upper engine mount QBM firewall mount IPD Poly lower Tranny mount NEW OEM Front engine mount for 302 rotors Brakes: 302mm Front rotor conversion -done 10k miles ago. New front calipers Front and rear calipers powdercoated blue Zimmerman cross-drilled rotors F&R - no cracking or warping New set of rotors in box included Akebono Ceramic pads F&R Stainless Steel brake lines F&R New hard lines across delta links New parking brake assembly Filled with ATE Super Blue fluid - one new unopened can included. Exterior: R front bumper Clear jewel headlamps Painted front grille with updated logo Clear bra on hood and front fenders IPD skid plate Volvo "Pegasus" wheels with 235/45/17 Blizzak LM-25 tires with only 4500 miles on them. Habrec Front Lip Paint- The entire right side was re-painted November '08 after a run in with a deer. I had more done than insurance would cover to take care of pre-existing scratches Inc. Front hood, RF Fender, Bumper, RF door, RR door, rear quarter & rear bumper. Left side of car is in good shape except for front fender and drivers door. Drivers door has clear coat peeling under molding and fender has rock chips - same with front bumper (again) Overall. I give the paint an 8 out of 10 Exhaust: 3" OBX downpipe with bungs SAS added wrapped with DEI heatwrap leading to a 3" QuickTime electric cutout followed by a magnaflow ceramic core racecat and a 3" mandrel bent exhaust finished off by a Mirror finish Magnaflow muffler with high polished 4" tip. Interior: Interior is virtually flawless with only the drivers seat showing only the slightest wear on the outboard bolster and drivers floormat also showing wear. Interior is stock except for the following: Window tint - Nebraska legal 35/20 F/R Antenna down switch from 960 wired in. Full SC-901 conversion from SC-816. Includes Dolby-Pro logic processor & Dynaudio speakers. Chrome gauge rings. Triple gauge pod with Glowshift blue digital gauges Wide band O2 Boost/Vac & EGT Oil Pressure Engine- I saved the best for last New radiator & expansion tank Engine was completely rebuilt over an 18 week process. S60R head gasket New main bearings LG Speed H beam connecting Rods Volvo OS1 pistons Complete rotating assembly balanced Block painted New valves, valve guide seals, P&P Complete new seals Unorthodox racing Underdrive pulley New PCV system New serpintine belt & Timing belt assembly New oil pump & water pump New fuel filter and Walbro 255LPh fuel pump Volvo Green injectors S60R exhaust manifold ported and ceramic coated 19T turbo with ceramic coated exhaust housing - also Wrapped in DEI exhaust wrap Forge Motorsport Wastegate actuator 15lb and 22lb springs included IPD HD TCV IPD HD CBV (with blue & red springs) IPD intercooler IPD RIP kit IPD Short Ram intake IPD Silicone plug wires Intake manifold smoothed out (exterior) & powdercoated. Inside ported. Camshaft cover Powdercoated MSD Blaster coil and 6AL Amplifier box NGK-R racing plugs (3 temp ranges colder thank stock) MTE 25 psi tune Custom done by Marco 2.75" polished intake pipe (made by sconeman) Stylin motors complete silicone vac lines and radiator hoses Unorthodox racing Underdrive pulley Vustom welded catch can I am sure that I am forgetting something. I have totaled up receipts over $21000 and I am asking $15000. I know that i this economy that may be hard to achieve, but I have to start somewhere and I will entertain SERIOUS OFFERS. NEW LOWER PRICE! Ebay reserve price of $13500.00 OBO!!! Please keep the your way outta line comments to yourself. While I do check here often, best way to reach me is to call me @ 402-881-1959. You tuve video Link to comment Share on other sites More sharing options...
T5wagon1717 Posted November 29, 2009 Report Share Posted November 29, 2009 Wow. I have to say this is probably one of the nicest S70's I have seen on the board. I'm very sorry to hear you have to get rid of it:( Great list of mods and very tasteful looking. Same color as mine and pretty much the same mods I would love to have done to mine in the future. How much hp do you think this puts out? Also, how is the automatic transmission holding up to the 19T and 25psi? Great car man. Whoever is in the market for an S70....if you have the money this looks like an amazing car. low miles too. ~Teal Link to comment Share on other sites More sharing options...
HeavyIron Posted November 29, 2009 Author Report Share Posted November 29, 2009 Only been on the dyno once, back in Septemeber right after crossing the 1,000 mile mark. @ 16psi it did 294hp @ 293tq on a Mustang Dyno. I need to get it back on the dyno now that I have the new wastegate actuator installed and the correct spring in place Auto tranny holds up fine with Mobil 1 and Lucas synthetic additive. shifts are solid and smooth Link to comment Share on other sites More sharing options...
B Mac Posted November 29, 2009 Report Share Posted November 29, 2009 :(:(:(:( I hate when stuff like this happens. Best of luck man, and hopefully your finances take a turn for the better :unsure: Link to comment Share on other sites More sharing options...
T5wagon1717 Posted November 29, 2009 Report Share Posted November 29, 2009 wow. Thats pretty darn good for a mustang dyno. So what do you think it would be around now that the boost is higher and such? Link to comment Share on other sites More sharing options...
GeraldJ Posted November 29, 2009 Report Share Posted November 29, 2009 Unreal man! I have only got to speak to you on the phone a couple times during your build up. I can assure anyone looking to buy this great example of a car that you will be getting a great deal! There was no expense spared and no corners cut when this car was put together. It really hurts my feeling to see someone pour there heart into something like this and the hard financial times take its toll. To be perfectly honest for a quicker sale and to regain some of your losses, you would be better off to try to return the car to stock and sell the performance parts separate. Your motor isnt much different that Scotts was when he sold it for how much? That ECU will bring a good price and if you sold it in a pack along with the turbo and wastegate it would bring a premium. Doing this you can regain some losses and still keep that beauty of a car. If you need anything at all dont hesitate to ask, Im almost local and have been up north a lot lately. Link to comment Share on other sites More sharing options...
HeavyIron Posted November 29, 2009 Author Report Share Posted November 29, 2009 Thanks Gerald, your comments mean a lot. Like Gary, I am just not ready yet to part it out. The time may come for that, but I would realy hope someone would enjoy it whole rather than stripped out. I have learned so much through this process. In time, there will be another, and next time Garrett BB rather than a 19t will be the focus point :) Link to comment Share on other sites More sharing options...
Canadianplat855 Posted November 30, 2009 Report Share Posted November 30, 2009 I was honestly just looking at vids on youtube. I could swear I just watched this car. I think we should start a paypal fund to save this from happening. Awesome car! Link to comment Share on other sites More sharing options...
HeavyIron Posted November 30, 2009 Author Report Share Posted November 30, 2009 I was honestly just looking at vids on youtube. I could swear I just watched this car. I think we should start a paypal fund to save this from happening. Awesome car! It's because you did. here is the link You Tube Link Link to comment Share on other sites More sharing options...
Commander Riker Posted November 30, 2009 Report Share Posted November 30, 2009 HeavyIron... I ran across your video randomly the other day on youtube. Nice build... hate to see you sell it. Link to comment Share on other sites More sharing options...
cr854r Posted November 30, 2009 Report Share Posted November 30, 2009 im sorry to hear about this, i have been following this for a long time Link to comment Share on other sites More sharing options...
JVC Posted November 30, 2009 Report Share Posted November 30, 2009 impressive... Swedish Car Specialists are the shit, they're the only place that I will take my car for repair if I cant do it myself. They are stand up guys so you know even though this car has seen a pretty major build, it definitely started in good hands before you bought it. I'd hate to see it go and not sure you'll get what you're asking unless you get the right buyer... but it's amazing. Ever been on a track? know what it runs in the 1/4? Link to comment Share on other sites More sharing options...
HeavyIron Posted November 30, 2009 Author Report Share Posted November 30, 2009 On a Garmin GPS it did 13.1 @ 105mph FTW Link to comment Share on other sites More sharing options...
B00STWAG1N Posted December 2, 2009 Report Share Posted December 2, 2009 thats damn fast for a 19t s70 holy crap! Link to comment Share on other sites More sharing options...
HeavyIron Posted December 4, 2009 Author Report Share Posted December 4, 2009 It's on Ebay people Here is the link. ebay link Link to comment Share on other sites More sharing options...
