jroot Posted December 3, 2009 Report Share Posted December 3, 2009 There is a hose that is behind the engine block, above the turbo heat shield, and it's very small...does anyone know the part # for this? If you follow the bottom hose on the coolant reservoir - that goes into something metal and if you follow that, it goes into a small hose and then back to metal. Thanks, Jay Link to comment Share on other sites More sharing options...
64pvolvo1800 Posted December 3, 2009 Report Share Posted December 3, 2009 There is a hose that is behind the engine block, above the turbo heat shield, and it's very small...does anyone know the part # for this? If you follow the bottom hose on the coolant reservoir - that goes into something metal and if you follow that, it goes into a small hose and then back to metal. Thanks, Jay The one on top is 31104675. The one on the bottom coolnat line is 6842190 and I think two different diameters. Link to comment Share on other sites More sharing options...
jdlc Posted December 3, 2009 Report Share Posted December 3, 2009 There is a hose that is behind the engine block, above the turbo heat shield, and it's very small...does anyone know the part # for this? If you follow the bottom hose on the coolant reservoir - that goes into something metal and if you follow that, it goes into a small hose and then back to metal. Thanks, Jay For the one you described, you can use 3/8 coolant hose they sell by the foot at parts store. I just used left-over 3/8 ATF cooling hose I have when I serviced my 16T. Link to comment Share on other sites More sharing options...
