HPTDoh Posted December 12, 2009 Report Share Posted December 12, 2009 All prices are shipped CONUS and are negotiable. I just want to get rid of this stuff. Badger Cyclone II Air Compressor - $125 Very nice airbrush compressor that has little use on it. Badger Crescendo 175 Airbrush - $50 Hardly used and comes with almost everything, but it's missing a needle tube. 850 NA Cams - $40 I've had these for a long time intending to install them, but I'm keeping my wagon pretty conservative. 850 A Pillar - $20 This came out of my 94 only to swap in one with a molded gauge pod. A/C bypass accessory belt NIB - $30 I bought this thinking about performance/weight gains, but I decided to get a standard belt instead. My loss is your gain Thermostat housing cover NIB - $15 I forgot why I have this Prosport Electric Boost Gauge - $20 Needs a new sending unit. I can include the defective one, plus brand new harnesses. Scantech sidemarkers - $20 Only getting rid of these because I installed 440 sidemarkers. Pics available for anything on request. Updates added as I find stuff Link to comment Share on other sites More sharing options...
RobT5M Posted December 12, 2009 Report Share Posted December 12, 2009 Def update on any 850 stuff you find! I read thru your list and was sad because I do not need anything... Whats the rating on the front speakers? 8 ohm? 104/95/94w? I took some rear door speakers out of a 97 854 and they were 104w and 8ohm. even though my old ones were 94w 8ohms *from my 96 854 after I blew the pass back door speak* Link to comment Share on other sites More sharing options...
echo5625 Posted December 12, 2009 Report Share Posted December 12, 2009 i assume the ecu is for a 94? Link to comment Share on other sites More sharing options...
HPTDoh Posted December 13, 2009 Author Report Share Posted December 13, 2009 Def update on any 850 stuff you find! I read thru your list and was sad because I do not need anything... Whats the rating on the front speakers? 8 ohm? 104/95/94w? I took some rear door speakers out of a 97 854 and they were 104w and 8ohm. even though my old ones were 94w 8ohms *from my 96 854 after I blew the pass back door speak* I didn't know 850s came with speakers with different ratings. I'll have to get back to you on that. i assume the ecu is for a 94? Couldn't tell you. I bought it online. It's probably spoken for, however Link to comment Share on other sites More sharing options...
RobT5M Posted December 13, 2009 Report Share Posted December 13, 2009 Alright let me know on the speaks, Should be on the back of the, will say like 8 ohm or 4 ohm, and 95w or something like that. Link to comment Share on other sites More sharing options...
HPTDoh Posted December 15, 2009 Author Report Share Posted December 15, 2009 Alright let me know on the speaks, Should be on the back of the, will say like 8 ohm or 4 ohm, and 95w or something like that. The midbass drivers only list the ohm rating: 4.. no power ratings. I'll check the tweeters when I have a chance to pull them out. Likely tomorrow. ECU is sold Link to comment Share on other sites More sharing options...
RobT5M Posted December 15, 2009 Report Share Posted December 15, 2009 The midbass drivers only list the ohm rating: 4.. no power ratings. I'll check the tweeters when I have a chance to pull them out. Likely tomorrow. ECU is sold OUCH 4 ohms would be a bit of a dg. Link to comment Share on other sites More sharing options...
HPTDoh Posted December 16, 2009 Author Report Share Posted December 16, 2009 If the tweeters are also 4 ohm, the final load would be 8.. In case it wasn't clear, these are OEM speakers Link to comment Share on other sites More sharing options...
RobT5M Posted December 16, 2009 Report Share Posted December 16, 2009 If the tweeters are also 4 ohm, the final load would be 8.. In case it wasn't clear, these are OEM speakers unfortunately I have 8 ohms for all speakers. dash, doors, rear. Link to comment Share on other sites More sharing options...
HPTDoh Posted December 16, 2009 Author Report Share Posted December 16, 2009 Strange. I thought for sure they were all interchangeable. Now I know Link to comment Share on other sites More sharing options...
RobT5M Posted December 16, 2009 Report Share Posted December 16, 2009 they are, just no sense in down grade right? Link to comment Share on other sites More sharing options...
HPTDoh Posted December 17, 2009 Author Report Share Posted December 17, 2009 they are, just no sense in down grade right? Depends on how you look at it. Less resistance means more power Headlight reflectors sold. Link to comment Share on other sites More sharing options...
Volvo_go_go Posted December 17, 2009 Report Share Posted December 17, 2009 Only missing the one attachment for the airbrush? Link to comment Share on other sites More sharing options...
HPTDoh Posted December 18, 2009 Author Report Share Posted December 18, 2009 Yes, ma'am. Looks like parts for it are readily available. Let me get a pic for you to show everything included. Link to comment Share on other sites More sharing options...
HPTDoh Posted January 9, 2010 Author Report Share Posted January 9, 2010 Man, I'm bad at following up with pics, but I added some stuff I found Link to comment Share on other sites More sharing options...
