rp850 Posted December 19, 2009 Report Share Posted December 19, 2009 Hi, 95 855T w/factory alarm system I'm having a remote starter installed soon and was curious if there was a resistor embedded in the ignition key? Does anyone know? Apparently if there is I would assume it's in the black rectangular part of the key but I'm not sure. If there is one, I'll need an additional bypass module for the remote starter. Thanks! Link to comment Share on other sites More sharing options...
mkc70 Posted December 19, 2009 Report Share Posted December 19, 2009 Hi, 95 855T w/factory alarm system I'm having a remote starter installed soon and was curious if there was a resistor embedded in the ignition key? Does anyone know? Apparently if there is I would assume it's in the black rectangular part of the key but I'm not sure. If there is one, I'll need an additional bypass module for the remote starter. Thanks! IIRC the US models started in 99 for chipped keys. Link to comment Share on other sites More sharing options...
rp850 Posted December 19, 2009 Author Report Share Posted December 19, 2009 Thanks for the reply. I kinda figured the 95 was a little early for the resistor in the key. That is actually good news for me. Apparently, if there is a resistor in the key, the remote starter I'm getting will require an additional bypass module (and additional $). Thanks again. IIRC the US models started in 99 for chipped keys. Link to comment Share on other sites More sharing options...
mkc70 Posted December 19, 2009 Report Share Posted December 19, 2009 Thanks for the reply. I kinda figured the 95 was a little early for the resistor in the key. That is actually good news for me. Apparently, if there is a resistor in the key, the remote starter I'm getting will require an additional bypass module (and additional $). Thanks again. Yup, it would require a stuff a key box and a coded key. They will need to hit the factory disarm wire, but that is just one wire off the RS unit. Link to comment Share on other sites More sharing options...
Jippi 855 GLT Posted December 19, 2009 Report Share Posted December 19, 2009 you just need to disarm the factory alarm with the disarm wire from the alarm/remote start and it should be good to go. Link to comment Share on other sites More sharing options...
rp850 Posted December 20, 2009 Author Report Share Posted December 20, 2009 Great. Sounds straightforward enough! Thanks. you just need to disarm the factory alarm with the disarm wire from the alarm/remote start and it should be good to go. Link to comment Share on other sites More sharing options...
