HeavyIron Posted December 22, 2009 Report Share Posted December 22, 2009 So, I go to get my car re-dynoed and I am trying a new shop called C&S Motorsports. Real nice guys. They were going to give me tons of data, with boost, AFR, Fuel pressure, Ignition Adv., and Injector duty cycle. So we get the car setup and do a few test pulls to get the rpm trigger and a few other sensors working right and then get into the real dyno pulls. After the first run, check engine light comes on and my temp gauge nosedives along with my AFR's. Scantool says low voltage- coolant temp sensor. Eff my life. Car thinks it is cold so its dumping fuel and running pig rich. I clear the code and try to get one more run, but AFR's come back at 10.0-10.5 and my horsepower has gone in the toilet (like 242whp) Sooo, back to the shop for more repairs. I swear the car spends more time there than in my own garage Link to comment Share on other sites More sharing options...
550 Posted December 22, 2009 Report Share Posted December 22, 2009 Join the club :-/ At this stage of the game, I know the CEL will come on after I fix another problem. I fixed the lower rad hose, then the upper rad hose went, as well the ECT went. Then the baro sensor went. Now the car stalls when I'm braking. It never ends! Link to comment Share on other sites More sharing options...
EricF Posted December 22, 2009 Report Share Posted December 22, 2009 Coolant temp sensor is a 5 minute job with an open end wrench... Get on it! Link to comment Share on other sites More sharing options...
db130 Posted December 22, 2009 Report Share Posted December 22, 2009 add a 180 deg thermostat while you are at it! a new coolant temp sensor could be considered part of stage 0! LOL Link to comment Share on other sites More sharing options...
lookforjoe Posted December 22, 2009 Report Share Posted December 22, 2009 Sorry to hear it! Next.... No, hopefully it'll go smoothly after this. :) Link to comment Share on other sites More sharing options...
mdlimy Posted December 22, 2009 Report Share Posted December 22, 2009 wasted dyno runs are super lame i feel ya man. Link to comment Share on other sites More sharing options...
HeavyIron Posted December 22, 2009 Author Report Share Posted December 22, 2009 add a 180 deg thermostat while you are at it! a new coolant temp sensor could be considered part of stage 0! LOL this will be 2nd temp sensor in 2500 miles..... Link to comment Share on other sites More sharing options...
troyhyde Posted December 22, 2009 Report Share Posted December 22, 2009 Don't screw the sensor in too tight, it makes the center probe pop out. Link to comment Share on other sites More sharing options...
550 Posted December 22, 2009 Report Share Posted December 22, 2009 Hey out of curiosity what is your gauge on the dash showing? Is the coolant temp sensor on the t-stat the sender for the gauge? Link to comment Share on other sites More sharing options...
EricF Posted December 22, 2009 Report Share Posted December 22, 2009 Hey out of curiosity what is your gauge on the dash showing? Is the coolant temp sensor on the t-stat the sender for the gauge? Yes, and it should drop to the bottom of the range... Link to comment Share on other sites More sharing options...
Pops Racer Posted December 22, 2009 Report Share Posted December 22, 2009 Volvo sensor only, no A/M. Link to comment Share on other sites More sharing options...
550 Posted December 23, 2009 Report Share Posted December 23, 2009 Funky. My OBDII was reading around 300 degrees, but the gauge never moved. The ECT was faulty though... confusing. Link to comment Share on other sites More sharing options...
randomdude Posted December 23, 2009 Report Share Posted December 23, 2009 ^could be the temp gauge itself. mine will drop sometimes, and i have DTC codes for the gauge/dash, but not the ECT sensor. Link to comment Share on other sites More sharing options...
HeavyIron Posted December 23, 2009 Author Report Share Posted December 23, 2009 Volvo sensor only, no A/M. Just bought another oem today $52.00 again. Will replace tomorrow. New Volvo coolant is blue. that's cool.... Link to comment Share on other sites More sharing options...
Pops Racer Posted December 23, 2009 Report Share Posted December 23, 2009 Thumbs up. Link to comment Share on other sites More sharing options...
