KlausC Posted December 31, 2009 Report Share Posted December 31, 2009 I have a friend who is trying to install a set of rails from a junked V70 2000 on to his 1996 850. He claims that he took off the plastic strip from the base of the windshield to the lift gate on the 850 and cannot find any holes to screw in the 'new' rails. I had thought all wagons came with the screw holes in place, even if the car didn't have the rack installed. Am I wrong? Is there another layer to take off? My 1998 already had brackets installed. Thanks, Klaus Link to comment Share on other sites More sharing options...
Ronny Posted December 31, 2009 Report Share Posted December 31, 2009 I have a friend who is trying to install a set of rails from a junked V70 2000 on to his 1996 850. He claims that he took off the plastic strip from the base of the windshield to the lift gate on the 850 and cannot find any holes to screw in the 'new' rails. I had thought all wagons came with the screw holes in place, even if the car didn't have the rack installed. Am I wrong? Is there another layer to take off? My 1998 already had brackets installed. Thanks, Klaus The holes are there. They're probably filled with the goop that holds the trim clips in place. Using the rail as a guide, have your friend look closely where the holes should be. He'll find them. Link to comment Share on other sites More sharing options...
Dave 54 Posted December 31, 2009 Report Share Posted December 31, 2009 They are there, as mentioned probably hidden by some black like tar, leave the tar there it's there to keep water out just drive the mounting screws through it. Link to comment Share on other sites More sharing options...
KlausC Posted December 31, 2009 Author Report Share Posted December 31, 2009 They are there, as mentioned probably hidden by some black like tar, leave the tar there it's there to keep water out just drive the mounting screws through it. Thanks guys! Just what I needed to hear. A small pick is in order to go through the goop :) Link to comment Share on other sites More sharing options...
