Tom. Posted January 1, 2010 Report Share Posted January 1, 2010 was driving today and i hit the brake and the pedal was so hard to push. i could barly stop the car and i had to drive like 30 minutes home. car is about due for new brake pads. its freezing here but it locked up after like 20 minutes of driving... frozen caliper might be a possibility. anything else? Link to comment Share on other sites More sharing options...
scandalo Posted January 1, 2010 Report Share Posted January 1, 2010 Define hard to push. Link to comment Share on other sites More sharing options...
Tom. Posted January 1, 2010 Author Report Share Posted January 1, 2010 umm... using my arms on the wheel to use my full body weight the push the pedal and even then barly working... doing that for a 30 minute drive hone in the snow...so fun... Link to comment Share on other sites More sharing options...
scandalo Posted January 1, 2010 Report Share Posted January 1, 2010 Sounds like the master cylinder is failing. Bleed the brakes and see if that helps. Even if it doesn't fix it you should get an idea of what is going on while doing it. Link to comment Share on other sites More sharing options...
Tom. Posted January 1, 2010 Author Report Share Posted January 1, 2010 all fixed! the vacuum line on the car going to the master cylinder has a Y split in it and a joint fail and broke on it so it wasnt getting any pressure. temp fix was hot glue and duct tape i dont want to drive on that but tommarow ill go get a replacement part :) Link to comment Share on other sites More sharing options...
Chilled man Posted January 1, 2010 Report Share Posted January 1, 2010 cool that was my first guess acutally broken hose from the brake booster to the intake Link to comment Share on other sites More sharing options...
Tom. Posted January 2, 2010 Author Report Share Posted January 2, 2010 wasnt that hose exactly it was that Y peice. i dont even know what its called so i cant find it to replace it ill just get a junkyard peice Link to comment Share on other sites More sharing options...
