HayaCruza Posted January 6, 2010 Report Share Posted January 6, 2010 Is your '97 850 turbo or not and does your car have fuel pressure damper instead of vacuum controlled fuel pressure regulator? HPT and pressure controlled FPR Just saying, in the US a 97 850 (at least HPT) had 4.3 Good Luck! Link to comment Share on other sites More sharing options...
cheapwagon Posted January 6, 2010 Report Share Posted January 6, 2010 HPT and pressure controlled FPR Just saying, in the US a 97 850 (at least HPT) had 4.3 Good Luck! 4.3 in my LPT. Link to comment Share on other sites More sharing options...
misa Posted January 6, 2010 Author Report Share Posted January 6, 2010 Well,as i can see all of your cars are turbo models(lpt or hpt),mine is non-turbo. It's '97 850 2.5 20v b5254s(125kw-170hp)non-turbo. I also read that all turbo models,even if they are made in 1997.,have Motronic 4.3. -Mine have fuel pressure damper(not vacuum controlled fpr like almost all 850's have) -I have just one fuel line attached near timing belt cover going to fuel rail(i don't have fuel return line) -i have air pump -pcv box number is 1271988 like on s,v70 models(not #9146756 like all 850's have) So...according to that i was preety sure that i have Motronic 4.4. Do you guys still think that i have Motronic 4.3? Can anyone of you guys tell me how can i know for sure which ecu i have...4.3 or 4.4?How can i find out that? Thanks all of you for the answers. Misha. Link to comment Share on other sites More sharing options...
misa Posted January 7, 2010 Author Report Share Posted January 7, 2010 Come on guys...i could really use a little help here! Link to comment Share on other sites More sharing options...
bum2kev Posted January 8, 2010 Report Share Posted January 8, 2010 have you looked at your ecu by chance.... Link to comment Share on other sites More sharing options...
misa Posted January 8, 2010 Author Report Share Posted January 8, 2010 Yes,there are Bosch numbers and some other numbers.There is nothing like Motronic on it. It's should be Motronic 4.3 or 4.4,because i'm sure it isn't jetronic or fenix 5.2. Fenix is fitted only in 10 valve cars,Jetronic is pre '96 and have 3 ecu's in ecu box.Mine have two,one for engine & other for transmission. Link to comment Share on other sites More sharing options...
bum2kev Posted January 8, 2010 Report Share Posted January 8, 2010 what are the ecu numbers. Link to comment Share on other sites More sharing options...
misa Posted January 8, 2010 Author Report Share Posted January 8, 2010 I'll post'em back as soon as i can. Link to comment Share on other sites More sharing options...
misa Posted January 8, 2010 Author Report Share Posted January 8, 2010 Ok,here are the numbers.... Engine ecu is the second one from left to the right: Bosch numbers:0 261 204 294 1766 0178 66429 810(this number is circled) Made in Germany Here are the numbers above barcodes: P 01275566 C001 1T2654502 T96120178 The big mark is F6.2 Link to comment Share on other sites More sharing options...
bum2kev Posted January 8, 2010 Report Share Posted January 8, 2010 its 4.4 from what i can see. looks like it cross references with the s70 v70 ECU. but who knows... it may be some type of hybrid... Link to comment Share on other sites More sharing options...
misa Posted January 8, 2010 Author Report Share Posted January 8, 2010 Forget it guys,i found that my car have Motronic 4.4. Here is the source: http://www.volvo850.ru/engine.htm Thanks to all of you who tried to help. Misha. Link to comment Share on other sites More sharing options...
