berad Posted January 10, 2010 Report Share Posted January 10, 2010 My 2003 XC70 w/ 93K just popped the CEL and in checking the code I came up with P2407 Evaporative Emission System Leak Detection Pump Sense Circuit Intermittent/Erratic Has anyone else experienced this? Are we just talking about clearing the code and try a new gas cap or do I need to get this in? Of course my inspection is due this month too, not sure if this is a killer or not. Your feedback is appreciated. Thanks, Brad Link to comment Share on other sites More sharing options...
FCP Euro Posted January 11, 2010 Report Share Posted January 11, 2010 EVAP codes can pop up for the simplest of things. I had one pop up for my gas cap being loose once. I have also had it come up when I had a vacuum leak. I would first check your gas cap and then check all the vacuum lines under the hood to make sure they are all still good. Link to comment Share on other sites More sharing options...
MrWinkey Posted January 12, 2010 Report Share Posted January 12, 2010 You probably need a pump common failure. Link to comment Share on other sites More sharing options...
toohipsi Posted January 15, 2010 Report Share Posted January 15, 2010 You probably need a pump common failure. Yes it is very common, the LDP is located on top of the rear subframe right next to the rear muffler. Alot of times you have to lower the exhaust and remove the heat shield above the muffler to gain access to the pump. Hope this helps. Matt Link to comment Share on other sites More sharing options...
berad Posted February 23, 2010 Author Report Share Posted February 23, 2010 My CEL has been going on and off for me to procrastinate awhile since I started this post - anyway - I had enough stuff driving me nuts that took it to my local indy shop and it just needs a software update along with unrelated items such as a new cabin blower motor, a motor mount and manifold gasket -- The odometer is at 94K right now. Link to comment Share on other sites More sharing options...
