Jozone Posted November 29, 2004 Report Share Posted November 29, 2004 A friend of mine just bought a sub/box/amp, and is looking to install them in his sedan. I have little/no experience using high level inputs, but am wondering what the best solution is to providing signal to the amp. His rear deck consists of 2 6x9's powered by factory amps. I just wish I could convince him to buy an aftermarket deck (and a volvo). Link to comment Share on other sites More sharing options...
Bing_0 Posted November 30, 2004 Report Share Posted November 30, 2004 well, just get a high/lo converter, wire it up to his back deck speaker wires, you will see that the input side of hte converter is two pairs of wires, and there is a set of rcas coming out the other side. there may be a knob that attenuates the signal as needed...anyway, basically, just tap the speaker wires, run a rca cable into the amp, and then find a good wire to use as a remote turn on lead, and oyu are set to go.b Link to comment Share on other sites More sharing options...
Jozone Posted November 30, 2004 Author Report Share Posted November 30, 2004 well, just get a high/lo converter, wire it up to his back deck speaker wires, you will see that the input side of hte converter is two pairs of wires, and there is a set of rcas coming out the other side. there may be a knob that attenuates the signal as needed...anyway, basically, just tap the speaker wires, run a rca cable into the amp, and then find a good wire to use as a remote turn on lead, and oyu are set to go.b←and should I be doing this to incorporate both left+right rear speakers or just pick a side? Link to comment Share on other sites More sharing options...
bogelo Posted November 30, 2004 Report Share Posted November 30, 2004 A friend of mine just bought a sub/box/amp, and is looking to install them in his sedan. I have little/no experience using high level inputs, but am wondering what the best solution is to providing signal to the amp. His rear deck consists of 2 6x9's powered by factory amps. I just wish I could convince him to buy an aftermarket deck (and a volvo).←Some amps have high level inputs. There is a better way than using the high-low adapter, you can buy an active crossover (Most phoenix gold crossover has high-level input). You'll get better processing, better frequency separation, and lastly better sound. It's like killing 3 birds at once :) Link to comment Share on other sites More sharing options...
Bing_0 Posted November 30, 2004 Report Share Posted November 30, 2004 i always use both sides of the speaker leads to use as high level inputs, yeah, if your amp has a high level built in, use that, but i would use both sidesb Link to comment Share on other sites More sharing options...
