rbodor3 Posted January 26, 2010 Report Share Posted January 26, 2010 For those that have done a leakdown test on our cars, this is the first time I've done it. Advice, tips, walkthru accepted.... Link to comment Share on other sites More sharing options...
rbodor3 Posted January 30, 2010 Author Report Share Posted January 30, 2010 Well it's as easy as any other leakdown test, for the most part. With of course the exception of the TDC mark on the head FYI this requires a 30mm socket for S60 to turn hand crank the car Here's my results, and I need some help interpreting this if somebody can step in. I did multiple checks and took an average number to make sure these were reliable, all @ about 100PSI (read from pass->drivers sides) 1. 25% all heard thru dipstick 2. 27% all headr thru dipstick 3. 20%, all heard thru dipstick 4. 20% dipstick 5. 15% dipstick I think I should do a compression test because these are a bit off from each other more than I would like. There was also a massive amount of oil leaking into the 4th cylinder, i will post pictures this evening. Link to comment Share on other sites More sharing options...
S8ET6 Posted January 30, 2010 Report Share Posted January 30, 2010 I'm not quite following you. How do you know oil is leaking into cylinder # 4? Are you saying that you pressurized your system to find boost leaks or conducted a compression leakdown test? Link to comment Share on other sites More sharing options...
rbodor3 Posted January 30, 2010 Author Report Share Posted January 30, 2010 I posted this into the performance section, because my new question really is more about the performance of the engine's being affected by these numbers not really maintenance, http://volvospeed.com/vs_forum/index.php/topic/128755-leakdown-test/ Link to comment Share on other sites More sharing options...
MrWinkey Posted January 31, 2010 Report Share Posted January 31, 2010 :lol: :unsure: Link to comment Share on other sites More sharing options...
