DB855R Posted January 26, 2010 Report Share Posted January 26, 2010 Have and 855R and done almost a complete stage 0 1yr ago. Car starts fine hot or cold and no blue smoke or rough idle. Once car is warm headlights start to dim, heater cuts out and car just stalls like a complete electrical short. No CEL, nothing, and to make it worst it won't restart right after. After it stalls no interior lights, dash lights ect. car is just dead. I usually have to wait 3-4 minutes and once I turn key to ACC starts right up with no problems. Car has a new fuel pump and fuel filter New Bosch Battery New IPD wires, bosch copper core plugs, new distributor New MSD ignition New timing belt 2 new bosch 02 sensors I cannot figure out the source of the problem. I used volt meter car gets 12 volts when off and 13-14 while running so I think my alternator is OK. I read some posts similar to this problem stating it might be fuel pump relay, MAF sensor or alternator problems but I believe if it was once it dies I would get some dash/interior lights at lease I did when my 4runner alternator died. Any help would be appreciated. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted January 26, 2010 Report Share Posted January 26, 2010 Fuel pump relay is original? Link to comment Share on other sites More sharing options...
Bah Posted January 27, 2010 Report Share Posted January 27, 2010 Fuel pump relay is original? Yup i used to have this issue BIG time with the original relay...It'd stall out, no turning back or attempting to start. I still have a similar issue...stalls out before warmed up generally when taking turns...hasn't done it since the ECC went kapoop completely, if thats coincidence or not. Pushed it to land, wait 1-2 minutes with key out, restart. I'm gonna put it out there though since i'm on this part atm....Your ECT...what is it's condition? Only say that cause you say it happens once the car heats up... Link to comment Share on other sites More sharing options...
DB855R Posted January 27, 2010 Author Report Share Posted January 27, 2010 Fuel pump relay is original? Still original will order on online today. Link to comment Share on other sites More sharing options...
DB855R Posted January 27, 2010 Author Report Share Posted January 27, 2010 I'm gonna put it out there though since i'm on this part atm....Your ECT...what is it's condition? Only say that cause you say it happens once the car heats up... ECT still original. I have a new in box ECT, thermostat, gasket and coolant, was waiting for spring to change coolant. good advice will change ECT next week Link to comment Share on other sites More sharing options...
troyhyde Posted January 28, 2010 Report Share Posted January 28, 2010 If your headlights dim, you have poor grounding. Clean up grounds and possibly replace the negative and/or positive battery cables. Link to comment Share on other sites More sharing options...
magicaljake Posted January 28, 2010 Report Share Posted January 28, 2010 engine ground? Link to comment Share on other sites More sharing options...
DB855R Posted February 4, 2010 Author Report Share Posted February 4, 2010 Thank you to everyone who replied. I cleaned the battery terminals with baking soda, added distilled water to battery cells and then replaced the fuel pump relay. I have drove the car for 2 days now with everything on (lights, radio, heater ect.) and no repeat of the stalling issue. Hopefully the fuel pump relay fixed it. Thank you all again! Link to comment Share on other sites More sharing options...
cn90 Posted February 4, 2010 Report Share Posted February 4, 2010 Next time this happens and if you suspect fuel relay, then: - Open the driver's side fuse box (Torx screwdriver) - Locate the Fuel Relay and remove it and jump terminals 15 and 87 on the connector. If the car now runs, then the fuel relay is defective. Link to comment Share on other sites More sharing options...
