chaze1385 Posted January 28, 2010 Report Share Posted January 28, 2010 THe transmission on my 94 T5 has started acting up recently. IF i floor it under 30mph( speed at which it will downshift to 1st) it will launch like a bullet then just bounce off the rev limiter. WOnt upshift by itself. At highway speeds if i floor it same thing, except once it hits 5000rpm it is like i threw it in neutral. Pings the rev limiter. FLuid is good. Drives and shifts fine as long as i dont floor it. ????/?? Link to comment Share on other sites More sharing options...
FCP Euro Posted January 28, 2010 Report Share Posted January 28, 2010 When you take your foot off the gas, does it upshift then? If the fluid is clean and pink, it could be an electrical issue. There are two solenoids inside the trans that help it shift. Other then that, the trans could just be on it's way out. Link to comment Share on other sites More sharing options...
chaze1385 Posted January 28, 2010 Author Report Share Posted January 28, 2010 It upshifts just fine when i let off or drive normal. i am thiking it is just time for another one. WIll a nonturbo 850 tranny work? CHad Link to comment Share on other sites More sharing options...
JordanW Posted January 29, 2010 Report Share Posted January 29, 2010 Just curious... How is the fluid - level and color? Do you have any codes in "A1"? for the transmission. But, yeah, one from a non- turbo will work. It does have a different final drive ratio though. Link to comment Share on other sites More sharing options...
chaze1385 Posted January 31, 2010 Author Report Share Posted January 31, 2010 No codes, and the fluid is good, Link to comment Share on other sites More sharing options...
