Sam Posted November 30, 2004 Report Share Posted November 30, 2004 When the alarm gets set off, there is no horn blow or anything. There is just a clicking sound. Any ideas?Thanks Link to comment Share on other sites More sharing options...
theunderlord Posted November 30, 2004 Report Share Posted November 30, 2004 When the alarm gets set off, there is no horn blow or anything. There is just a clicking sound. Any ideas?Thanks←no flashy lights? hmm... do your horns work normally? Link to comment Share on other sites More sharing options...
Sam Posted November 30, 2004 Author Report Share Posted November 30, 2004 yeah, the horn works fine, and the red led flashes when it's locked. I set it off one day - ulocked the car with the window open, and it apparently went off but only made a clicking sound (relay?). I had to unlock it to get it to stop. I think the lights flash, i'll check this evening to be sure. Perhaps a wire is loose somewhere or something is disconnected? Link to comment Share on other sites More sharing options...
MrWinkey Posted December 1, 2004 Report Share Posted December 1, 2004 If the light's are flashing the clicking noise you hear is the relay activating them ...as for the horn not working.. the security system has it's own horn it may just be disconnected, I'm sure the starter kill is still active Link to comment Share on other sites More sharing options...
Bay13 Posted December 1, 2004 Report Share Posted December 1, 2004 The horn for the alarm system is in the engine bay, center on the fire wall. There is a nut that holds part of the vibration plate in place, sometimes it falls off and the plate as well so the alarm horn doesn't work. Or The thing needs adjusting so it can vibrate. Look at the center there is a screw to adjust the tension on the diaphram. Give the horn a constant 12V from your battery and ajust the screw until the horn/alarm works. Link to comment Share on other sites More sharing options...
Sam Posted December 1, 2004 Author Report Share Posted December 1, 2004 Thanks, will check it out. Link to comment Share on other sites More sharing options...
