thewhiteguy1 Posted February 8, 2010 Report Share Posted February 8, 2010 okay. so i installed my boost gauge today. everything was fine, firewall passthrough etc went well. problem is the vac lines. i got 3/16 vac line, which was perfectly fine and all, but it doesn't exactly work with my gauge. gauge is an autometer cobalt 30inhg-20psi. the tubing is not big enough to fit with what is on the back of the gauge, and i cannot find anywhere that sells npt fittings with 3/16 barbs. help? Link to comment Share on other sites More sharing options...
v4lve Posted February 8, 2010 Report Share Posted February 8, 2010 ??? I have an autometer gauge and it uses hard line, not typical vac line. Did it come with any install kit or anything? I think i have a few feet of the hard line if you want Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted February 8, 2010 Author Report Share Posted February 8, 2010 ??? I have an autometer gauge and it uses hard line, not typical vac line. Did it come with any install kit or anything? I think i have a few feet of the hard line if you want got it off ebay. if hard line is that little plastic stuff i have that, but idk if it is enough to reach the vac tree. also the tiny piece that holds the line into place inside of the two things on the back is missing. weird. ugh. Link to comment Share on other sites More sharing options...
TrboBrk216 Posted February 8, 2010 Report Share Posted February 8, 2010 that little thing is called a "farrel" i believe, and personally, from my experience i wouldnt use anything but the hard plastic line the gauge comes with, because bigger vacuum line in my experience tends to collapse and cause inaccuracy. but as for that hard plastic line not reaching the vacuum tree, if it is still packaged and coiled up, it is PLENTY long enough to reach the vaccum tree. there are a couple of plastic t's that come with the gauge inside the box in the packaging, and there is a rubber reducer specifically for the plastic line, plastic line goes in the small end, and then the big end goes on to one side of the t. the other two side are to be ran in parallel with of course a vacuum line going to the intake manifold. hope that helps Link to comment Share on other sites More sharing options...
beadgc23 Posted February 8, 2010 Report Share Posted February 8, 2010 got it off ebay. if hard line is that little plastic stuff i have that, but idk if it is enough to reach the vac tree. also the tiny piece that holds the line into place inside of the two things on the back is missing. weird. ugh. You can get them from NAPA or similar - they're called compression sleeves though you'll get to learn that everyone in the store has a different name for them Get a few, once they're on and compressed you have to cut them off, they're only a few cents. 6' wasn't enough for my A pillar gauge, I had to extend it to the vacuum tree with the thinnest vac line i could get. Link to comment Share on other sites More sharing options...
cheapwagon Posted February 8, 2010 Report Share Posted February 8, 2010 I just did a combo of hard and silicon line and used zip ties. Link to comment Share on other sites More sharing options...
Dave 54 Posted February 8, 2010 Report Share Posted February 8, 2010 You can get them from NAPA or similar - they're called compression sleeves though you'll get to learn that everyone in the store has a different name for them Get a few, once they're on and compressed you have to cut them off, they're only a few cents. 6' wasn't enough for my A pillar gauge, I had to extend it to the vacuum tree with the thinnest vac line i could get. Go to Lowes they have the compression fittings you need. Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted February 8, 2010 Author Report Share Posted February 8, 2010 smallest size lowe's has for a compression fitting is 1/4" and that's too big for my gauge lol. I did find the missing parts for my homemade mbc though lol Link to comment Share on other sites More sharing options...
beadgc23 Posted February 15, 2010 Report Share Posted February 15, 2010 smallest size lowe's has for a compression fitting is 1/4" and that's too big for my gauge lol. I did find the missing parts for my homemade mbc though lol Hence the auto store recommendation - I had the same experience. Link to comment Share on other sites More sharing options...
thewhiteguy1 Posted February 19, 2010 Author Report Share Posted February 19, 2010 i ended up getting an npt fitting that was the same size as the input of the boost gauge and its all nice and dandy. Link to comment Share on other sites More sharing options...
v4lve Posted February 19, 2010 Report Share Posted February 19, 2010 Good to hear it all worked out Link to comment Share on other sites More sharing options...
