Rsterns Posted February 17, 2010 Report Share Posted February 17, 2010 If this is on the 940, and if it's the same as my '96 960, there is a small black plug near the trip reset in the main instrument cluster, you remove that plug, and take a blunt tooth pick or equivalent, and with the ignition turned to on, press the button under the plug with the tooth pick until the light resets. Link to comment Share on other sites More sharing options...
VolvoRine Posted February 17, 2010 Author Report Share Posted February 17, 2010 If this is on the 940, and if it's the same as my '96 960, there is a small black plug near the trip reset in the main instrument cluster, you remove that plug, and take a blunt tooth pick or equivalent, and with the ignition turned to on, press the button under the plug with the tooth pick until the light resets. Yeah I know that it works for the 940...I do that when is needed but for the 850R it doesn't have one <_< Link to comment Share on other sites More sharing options...
cn90 Posted February 18, 2010 Report Share Posted February 18, 2010 If you ever need to remove the instrument cluster for removing light bulbs etc. I wrote a DIY here (a few bulbs can be approached from BELOW w/o the need to remove the dash): http://volvoforums.com/forum/showthread.php?t=38386 Link to comment Share on other sites More sharing options...
Ozark Lee Posted February 18, 2010 Report Share Posted February 18, 2010 Step 1: Remove SRL bulb. Step 2: Done I usually take the CEL bulb out while I'm in there. No emissions testing FTW. I used to stomp on my service light lamp after I removed it (before I got VOL-FCR) and then I threw it down the street just to make sure that it can never come back. The CEL I leave intact just so that I know when a vacuum line has fallen off. Limp mode will kill your fuel mileage. ...Lee Link to comment Share on other sites More sharing options...
Bah Posted February 18, 2010 Report Share Posted February 18, 2010 I used to stomp on my service light lamp after I removed it (before I got VOL-FCR) and then I threw it down the street just to make sure that it can never come back. The CEL I leave intact just so that I know when a vacuum line has fallen off. Limp mode will kill your fuel mileage. ...Lee :lol: Link to comment Share on other sites More sharing options...
VolvoRine Posted February 20, 2010 Author Report Share Posted February 20, 2010 Limp mode will kill your fuel mileage. ...Lee tell me about!! I did a 300 miles trip to Orlando last Christmas and it only gave 19mpg @ 60mph!! Limp Mode is not really helpful! <_< Link to comment Share on other sites More sharing options...
VolvoRine Posted February 20, 2010 Author Report Share Posted February 20, 2010 If you ever need to remove the instrument cluster for removing light bulbs etc. I wrote a DIY here (a few bulbs can be approached from BELOW w/o the need to remove the dash): http://volvoforums.com/forum/showthread.php?t=38386 thanks for the info Link to comment Share on other sites More sharing options...
BEJinFBK Posted February 20, 2010 Report Share Posted February 20, 2010 If you have a 1996-1998 850, S/V/C 70, then an expensive reset tool is needed to reset the service light. Here's an example. http://cgi.ebay.com/VOLVO-SERVICE-AND-AIRBAG-INDICATOR-RESET-TOOL_W0QQitemZ380192974472QQcmdZViewItemQQptZUK_Diagnostic_Tools_Equipment?hash=item5885446688 You can almost always find them at about 50-60 bucks. ( THIS one is going for about twice the usual eBay price. ) Link to comment Share on other sites More sharing options...
