G$850R Posted February 15, 2010 Report Share Posted February 15, 2010 i was going through my garage and i found a 10in ported sub and box and a 1000watt amp i was wondering if i could use my stock headunit instead of buying a new one. i heard there is some kind of line adapter? has anyone used these if so how did it work out. and help will be appreciated. Link to comment Share on other sites More sharing options...
Young Burnsy Posted February 15, 2010 Report Share Posted February 15, 2010 You need a Line Out Converter. Use this to tap into the rear deck speakers. Check out Crutchfield.com Link to comment Share on other sites More sharing options...
bdimag Posted February 16, 2010 Report Share Posted February 16, 2010 ^^ that... http://www.crutchfie...Converters.html also, some amps have that feature built in... so you may want to check that. look at the input side for anything that says "speaker-level" then you would use something like these: (one on left uses it's own 4 pin plug, the ones on the right use the same RCA ports on the amp, but there's a switch) Link to comment Share on other sites More sharing options...
beadgc23 Posted February 16, 2010 Report Share Posted February 16, 2010 Be careful - the 815/816 has this huge bass hump at 80Hz or so. You could end up wearing your sub cone as a hat. Hard to get rid of this without a flexible parametric EQ or a headunit that doesn't do this... Link to comment Share on other sites More sharing options...
BEJinFBK Posted February 16, 2010 Report Share Posted February 16, 2010 Most Volvo stock decks have a preamp level AMP connector on the back. It's a round, 6 pin DIN jack marked "AMP". Get the right adapter cable and you can plug right in... Search eBay for "Volvo Amp". Link to comment Share on other sites More sharing options...
bdimag Posted February 16, 2010 Report Share Posted February 16, 2010 now theres a though.... and just in case you miss it amongst all the alternators: http://cgi.ebay.com/ebaymotors/Volvo-Stereo-Radio-Aftermarket-HU-to-Factory-Amp-Cable_W0QQcmdZViewItemQQhashZitem2ea87bb681QQitemZ200395175553QQptZCarQ5fAudioQ5fVideo#ht_500wt_1182 Link to comment Share on other sites More sharing options...
BEJinFBK Posted February 16, 2010 Report Share Posted February 16, 2010 now theres a though.... and just in case you miss it amongst all the alternators: http://cgi.ebay.com/...o#ht_500wt_1182 Really close, but that's an Aftermarket HU to Volvo amp cable. He'd want this, if there's no existing Volvo amp: http://cgi.ebay.com/ebaymotors/Volvo-Stereo-Radio-Factory-HU-to-Aftermarket-Amp-Cable_W0QQitemZ200343379405QQcmdZViewItemQQptZCar_Audio_Video?hash=item2ea5655dcd Or this, if there is: http://cgi.ebay.com/ebaymotors/Volvo-Stereo-Radio-Add-an-Aftermarket-Amp-Cable_W0QQitemZ200396353458QQcmdZViewItemQQptZCar_Audio_Video?hash=item2ea88dafb2 Link to comment Share on other sites More sharing options...
beadgc23 Posted February 16, 2010 Report Share Posted February 16, 2010 I have one of his cables and they work fine - but you have to admit, that's one tiny niche market... Link to comment Share on other sites More sharing options...
Guest Todd B Posted March 2, 2010 Report Share Posted March 2, 2010 Just a note i used this guy's product and it worked great He'd want this, if there's no existing Volvo amp: http://cgi.ebay.com/...=item2ea5655dcd I have a s70 with the 816 head unit with two amps running off it and sounds great Link to comment Share on other sites More sharing options...
