badbrick Posted February 16, 2010 Report Share Posted February 16, 2010 Not really an audio/video topic, but I figured this would be the best area to pose this question: I have pretty much filled up the space available in the accelerator cable accessory grommet hole, but would like to run more wiring from the engine compartment into the passenger/ cabin area. Are there any other holes available to run wiring through the firewall? If not, would it be safe to drill a new hole nearby, install a grommet and run wires through there? If so, does anyone have any recommendations for a good spot to do this? Any ideas and help would be appreciated. Thanks, Dav Link to comment Share on other sites More sharing options...
GeraldJ Posted February 16, 2010 Report Share Posted February 16, 2010 Passenger side has a nice size hole and grommet. Link to comment Share on other sites More sharing options...
badbrick Posted February 16, 2010 Author Report Share Posted February 16, 2010 Sweet! Thanks for the info, I'll go look for it now!!! Dav Link to comment Share on other sites More sharing options...
Che'_Moderator Posted February 16, 2010 Report Share Posted February 16, 2010 You have to cut the sound insulation before you can see it. http://volvospeed.com/Mods/passenger_firewall_passthrough.html Link to comment Share on other sites More sharing options...
badbrick Posted February 16, 2010 Author Report Share Posted February 16, 2010 Found it just fine, from the engine compartment. Haven't removed the panel under the glovebox yet, to take look. I assume that's where the sound insulation is located that I need to cut away? Thanks again! Dav Found it just fine, from the engine compartment. Haven't removed the panel under the glovebox yet, to take look. I assume that's where the sound insulation is located that I need to cut away? Thanks again! Dav Edit: Shoulda looked at the link you provided before I replied:) Answers my question! Link to comment Share on other sites More sharing options...
aplejuce Posted February 28, 2010 Report Share Posted February 28, 2010 if you are looking to pass more on the driver side, you can pull wires between the fuse box (engine compartmnt) and the driver side foot area... pull the panel above the feet.. and remove the top plastic cover that hides the fuses (not the snap cover.. the surround, held in by a few bolts or screws. you can see through! great for passing power from bat to amp. + more still.. i wish i knew about the trick - through the passenger side! Link to comment Share on other sites More sharing options...
