How Do You Shift Automatic Transmission?
FAST850R
  • Replies 62
Sport mode, tape it down. I've been shifting from 1-2-3-d for a year now in attempts to kill my tranny (I have a manual swap waiting) and the fluid is black, gel and smells like sh!t, but its just not dying. It doesn't like to hold gears at 140, or at constant cruises, but thats okay with me. Just stay away from brake boosts, it tends to make your tranny slip like a lubed hotdog after a few of them with dirty fluid (I stopped that, might start again).
Redline N to D is also fun, but smells really bad, and it makes your car shake, but its fun as hell if you want it to die prematurley. Thats how you do nice burns with an auto and e-brake up. Do it next to a guy on a ducatti for extra lolz.
Brake boosting only hurts the tranny if your doing it forever as it causes the converter to heat up
WTF, thats the worst idea i EVER HEARD, if your car doesn't make enough power to spin them without neutral bombing it, DONT DO IT
:lol:
If the stories are true...a simple fluid flush should entail a fun manual swap weekend =p
This is def a terrible idea but if your looking to blow the tranny up - when i bought my car i had it for 3 months and my tranny went, turns out the previous owner was doing just this...
HOWEVER.
It has been proven that these 1996 auto trannys are some of the best around, they go through hell and back and are just fine a day later with a tranny flush and new fluid...
You might be in for that longer than you expect.
And now not quoting someone- my 2 cents:
If you learn how the kick down works you will find out that you have much more control over the car's acceleration than most manual drivers would expect... I wish my car was manual but i find just leaving it in D with Sport mode on works well, just need to adjust to the car's habbit's and lag times...
one thing I wish we could freaking figure out would be paddle/button shifters:
My thought here is- the TCU sends certain voltage based signals to the tranny (etc) to tell it to change gears... why can't we simulate that!!!! why can we not by pass that with a little box with some buttons on it labeled 1,2,3,4 each with corresponding to the proper voltage that the tranny will respond to and change to that gear!!!!
IIRC a couple of years ago Lucky was working on this. Not sure how it ended.
Its called an Auto, leave it in Drive, :rolleyes: i'm a hypocrite though sometimes when i drive the 850 i manually shift for maximum rpmzz, if your going from a dig, remember that there is a 500rpm lag between the time you shift from L - 3 and from 3 - D, i'm not sure what the turbo models hit the limiter at, but i shift the 850 at 6300rpms and it'll shift at 6800
FYI it's not fixed at 500 rpm for lag... It's a time lag, so in first gear it's more lag, second it's less, and also varies by how fast your car is (how much RPM will climb after you've shifted the lever and before the transmission actually shifts).
