JTSPO Posted December 6, 2004 Report Share Posted December 6, 2004 Ok. But, dang, $200 is still a lot more than I was expecting to pay for labor.←not for a job done right and safe. it's your money your life. My indie charge $300. Link to comment Share on other sites More sharing options...
Flyby Posted December 6, 2004 Report Share Posted December 6, 2004 While you are down there, you may want to replace your suspension bushings as wellhttp://fcpgroton.com/volvo850suspension.htm Link to comment Share on other sites More sharing options...
wattsat Posted December 7, 2004 Report Share Posted December 7, 2004 Go look at the thread where the guy paid $600 to have the shocks and struts replaced. And that did not even include parts. Link to comment Share on other sites More sharing options...
JehovArob Posted December 7, 2004 Report Share Posted December 7, 2004 :( Link to comment Share on other sites More sharing options...
BeachRat Posted December 7, 2004 Report Share Posted December 7, 2004 Okay, here's the full suspension list (since I'm doing the same thing in January):New Shocks/StrutsNew SpringsFront: Strut Mounts (2), Spring Seats (2), Sway Bar Links (2), Lock Nuts (6), Strut Bolts (4), Strut Bolt Lock Nuts (4), Strut Bump Stop (2), Strut Stop Washer (2), Strut Boot Cover (2)Rear: Shock Mounts (2)*I haven't found any nuts/bolts/washers to replace on the back*Please comment on anything I've missed or if I've put something in that REALLY doesn't need to ever be replaced unless it's broken.Edit: Scratch the rear spring seats that apprantly don't exist. Link to comment Share on other sites More sharing options...
Geevs Posted December 8, 2004 Report Share Posted December 8, 2004 Rear: Shock Mounts (2), Spring Seats (2) *I haven't found any nuts/bolts/washers to replace on the back*Please comment on anything I've missed or if I've put something in that REALLY doesn't need to ever be replaced unless it's broken.I think the rears do not use spring seats but only (the elliptical-shaped) shock mounts. Link to comment Share on other sites More sharing options...
eroc37 Posted January 11, 2005 Report Share Posted January 11, 2005 why do you run shock boots ?? maybe i am used to off road trucks, but we never run boots on anything....they seem to just hold mud and grime... IMHO Link to comment Share on other sites More sharing options...
KLS Posted January 14, 2005 Report Share Posted January 14, 2005 I'd suggest taking the car to a good idependent front end shop and ask them to look for worn parts. Get prices from them for replacing anything worn like tie rod ends or control arms.If one wants to do part of the job themselves they might ask a shop if they will put the springs on the new front struts for you for a reasonable charge. It is only a few minutes work for them with their professional spring compressor. The rest of the job is OK for any one who knows how to safely put the car up on jackstands and has some wrenches. Get a Haynes manual first, though.Rear shocks are not a tough job...put the rear of the car on jack stands and use a floor jack to compress the spring enough to fit the shock.Front spring seats and rear upper shock mounts may need replacement, but not usually every time the shocks/struts get replaced. That said, if you have Bilstein shocks/struts for 100,000 miles and get them replaced under warranty (save your original invoice), you'll likely need new spring seats & rear upper shock mounts. Be sure you get the rear lower shock nut plenty tight...I chased a rear clunk for months...one nut was tight but not tight enough.Ken Link to comment Share on other sites More sharing options...
