dyadeta Posted February 24, 2010 Report Share Posted February 24, 2010 Hey guys i am new here, i have an 08 s60 and need to remove the front bumper so i can get to the headlamps. I have an hid kit i want to install, searched around could not find anything. Any help is appreciated. Thanks Link to comment Share on other sites More sharing options...
Young Burnsy Posted February 24, 2010 Report Share Posted February 24, 2010 Are you installing new headlights or new bulbs? You shouldn't have to remove the bumper and headlights if you're just installing bulbs. Either way I know there is a write up some where on the whole procedure going from 01 style headlights to 05+ style. Link to comment Share on other sites More sharing options...
dyadeta Posted February 24, 2010 Author Report Share Posted February 24, 2010 Are you installing new headlights or new bulbs? You shouldn't have to remove the bumper and headlights if you're just installing bulbs. Either way I know there is a write up some where on the whole procedure going from 01 style headlights to 05+ style. I'm installing a whole hid kid, ballasts and all. I can't even reach my hand in there to remove the stock low beam. I also need a good place to mount the ballast. Is the bumper removal the same in 01-04? Thanx Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted February 25, 2010 Report Share Posted February 25, 2010 I haven't removed one in quite some time, so this may not be accurate. If I remember correctly the headlights can be removed without taking the bumper off. There should be two flat metal pins that slide right out and let you remove the assembly. Link to comment Share on other sites More sharing options...
