brr2f Posted December 3, 2004 Report Share Posted December 3, 2004 Is the opening in a '94 850 large enogh for a 5.25" kappa or will I need to cut the extra 13mm of metal off as it says to do on volvospeed's mod. section? I only ask because I need to borrow some tools as the system arrives tomorrow. Link to comment Share on other sites More sharing options...
tboyko Posted December 3, 2004 Report Share Posted December 3, 2004 Is the opening in a '94 850 large enogh for a 5.25" kappa or will I need to cut the extra 13mm of metal off as it says to do on volvospeed's mod. section? I only ask because I need to borrow some tools as the system arrives tomorrow.←you will need to cut. It's just not deep enough for the magnet. I found that the easiest and cleanest thing to do is actually make a few dremel incisions and then hammer the metal flat to make more room, instead of actually grinding it all away. btw, I made my dremel overheat and also burnt out my friends power drill (oops) so that's partially why I preferred to hammer out my second door. Link to comment Share on other sites More sharing options...
brr2f Posted December 3, 2004 Author Report Share Posted December 3, 2004 was it fairly easy to do tbokyo? Link to comment Share on other sites More sharing options...
steve s Posted December 3, 2004 Report Share Posted December 3, 2004 yes and no.i know someone on the board said it fit his 850didn't fit mine.look up charles on his mod, go to the mod section on this website.just tape off all the holes/crevices to catch any stray metal shaving. repaint to seal again. Link to comment Share on other sites More sharing options...
tboyko Posted December 3, 2004 Report Share Posted December 3, 2004 was it fairly easy to do tbokyo?←I would not say easy, but i wouldn't say super hard either. I just made a few cuts so that i could then flatten it out. A warning though, I had to take the speaker out and put some electrical tape along the back of the door because I think my speaker terminals or magnet was occasionally grounding out through the door and creating a TON of noise in my speaker and matching component tweet.you can see a pic here: http://www.7cures.com/gallery/view_photo.p...004&id=IMG_1513on that door, i dremeled that little edge, but on the left door, i just made some perpendicular cuts with respect to the circular cutout and then flattened. much cleaner and quicker. Link to comment Share on other sites More sharing options...
steve s Posted December 4, 2004 Report Share Posted December 4, 2004 used speaker baffles on my end... partly because i was pretty sure the rear speakers had a shield on top to protect it from water in the event the window gets rolled down. and in fact i did find it wet on one occassion when i took apart the panel after a rainy day. aftermarket speakers don't have shields, so i put speaker baffles in all the doors.. Link to comment Share on other sites More sharing options...
