FAST850R Posted March 1, 2010 Report Share Posted March 1, 2010 Hi, Do you guys put tracs on or off when you drive your 850? Any differences do you guys feel with and without traction control? one more question, how do you adjust throttle cable? I want to make my car little bit more responsive. unless I use kick down switch, this car goes quite slow.... My car is 1996 850r with 140k miles. Thanks. Link to comment Share on other sites More sharing options...
BurgerBob Posted March 1, 2010 Report Share Posted March 1, 2010 Turn the tracs off! It's like trying to launch from second gear. Link to comment Share on other sites More sharing options...
FAST850R Posted March 1, 2010 Author Report Share Posted March 1, 2010 Turn the tracs off! It's like trying to launch from second gear. Thank you for the reply. OK, I will turn it off When do you use it then? When I drive my car on snow? Link to comment Share on other sites More sharing options...
BurgerBob Posted March 1, 2010 Report Share Posted March 1, 2010 Thank you for the reply. OK, I will turn it off When do you use it then? When I drive my car on snow? Yes, that would be a good instance. I live in New Orleans where that's never an issue...if it's snowing here, I'm not driving. Link to comment Share on other sites More sharing options...
project_850 Posted March 1, 2010 Report Share Posted March 1, 2010 Turn the tracs off! It's like trying to launch from second gear. Not sure if my Tracs even does anything, on or off I break loose in 1st and 2nd. A little off topic but, I'm pretty sure that some of the high horsepower guys are launching in second... For the longest time I was wondering how the hell they could trap 125mph in 3rd gear: Autotech S70 Link to comment Share on other sites More sharing options...
turboVULVA Posted March 1, 2010 Report Share Posted March 1, 2010 FML I've been driving my auto with it on =0P Link to comment Share on other sites More sharing options...
Austin H Posted March 1, 2010 Report Share Posted March 1, 2010 Volvo 850 traction control is a joke. Link to comment Share on other sites More sharing options...
TRACStar Posted March 1, 2010 Report Share Posted March 1, 2010 Volvo 850 traction control is a joke. This The technology wasn't there in the mid 90's to handle a FWD car with the amount of torque a modded T5 lays down. I launched my car before to show some guy I used to work with that it was nothing to shake a stick at. Left the TRACS on by mistake and left dotted lines in the street.... One side spun until the TRACS caught it then the other side spun and it did it back and forth like 6 times before it hooked Good for a laugh....bad for performance ;) Link to comment Share on other sites More sharing options...
caanglin Posted March 1, 2010 Report Share Posted March 1, 2010 I turn it off every time I get in the car. Link to comment Share on other sites More sharing options...
Mesoam Posted March 1, 2010 Report Share Posted March 1, 2010 don't worry it'll turn it self off when your ABS module goes bad Link to comment Share on other sites More sharing options...
caanglin Posted March 1, 2010 Report Share Posted March 1, 2010 That happened and it was nice for a while. But then the pump starting kicking in while driving down the road, so I got a rebuilt one. Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted March 1, 2010 Report Share Posted March 1, 2010 Hi, Do you guys put tracs on or off when you drive your 850? Any differences do you guys feel with and without traction control? one more question, how do you adjust throttle cable? I want to make my car little bit more responsive. unless I use kick down switch, this car goes quite slow.... My car is 1996 850r with 140k miles. Thanks. Re: throttle cable. Use sport mode. If you're looking for more immediate throttle response within your current gear, and you're sure you have no vacuum leaks, then you're probably going to want a higher compression motor. If you shorten your throttle cable, you will just make the car idle higher and it will be like driving around with 1/4 throttle all the time. Modifications that increase throttle response are a lighter and/or larger diameter crank pulley, and poly motor mounts. Neither will probably give you the kind of low end 'pep' you are looking for. FYI, since I'm betting you don't know this, TRACS is auto disabled after 25mph Thank you for the reply. OK, I will turn it off When do you use it then? When I drive my car on snow? You can use it when you drive in snow, but it probably won't help you much. Link to comment Share on other sites More sharing options...
83' turbo Posted March 1, 2010 Report Share Posted March 1, 2010 don't worry it'll turn it self off when your ABS module goes bad hahahaha +1, so true Link to comment Share on other sites More sharing options...
InitialDriveGTR Posted March 2, 2010 Report Share Posted March 2, 2010 FYI, since I'm betting you don't know this, TRACS is auto disabled after 25mph Did not know this. thanks Link to comment Share on other sites More sharing options...
turboVULVA Posted March 2, 2010 Report Share Posted March 2, 2010 so then I can just leave it on when im DDing right? It will do no harm? Link to comment Share on other sites More sharing options...
