Roger B. Posted March 1, 2010 Report Share Posted March 1, 2010 I was sent here with a link that doesn't work anymore.... This link: http://www.volvospeed.com/vs_forum/index.php?act=ST&f=13&t=4665 found in this article : http://volvospeed.com/obd2/subinstall3.htm I am looking for a way to connect the allready built in aftermarket amplifier with 4x RCA connectors to my Volvo CT 906 radio. At the back there is a DIN-like connector looking at the back side of the radio it's at the right corner next to is there is "AMP" in the metal so I suspect it to be a pre-amp-out. The link should send me to a guide to make an adapter from this DIN-connector to RCA-jacks... Can anyone help me with this? Link to comment Share on other sites More sharing options...
crazykn Posted March 1, 2010 Report Share Posted March 1, 2010 I believe you need the link in my post signature. A while back I wrote a write-up on how to make the adapter. You will also need the article in the reference section of the Volvospeed main page to build the 4 channel version of my adapter. By the way, what is the CT-906? is this for a newer Volvo? P.S. The article is slightly out of date. The correct part number for the 6-Pin DIN Connector is 171-0276 at mouser.com and it cost less too! Link to comment Share on other sites More sharing options...
BEJinFBK Posted March 2, 2010 Report Share Posted March 2, 2010 You'll find several prefab options on eBay. Search "Volvo Amp". Link to comment Share on other sites More sharing options...
Roger B. Posted March 2, 2010 Author Report Share Posted March 2, 2010 By the way, what is the CT-906? is this for a newer Volvo? THe radio has previously been used in a Volvo V40 (european car, I don't know weather Volvo uses the same types in the US) THe owner hes bought a new used car last week, a Volvo C70 manufactured in 2000 with a 2,4 turbo engine. He would like his radio (CT 906) to work in his new car, but the precious owner has built in a after-market amplifier and the "normal" speaker wires could not be found in the space where the radio should be. There are 4 RCA-type cables AND the original din-calble behind the radio, so I suspect there has been an factory amplifier in the left rear wing, but the previous owner has taken that out and replaced it with an after-market amplifier. I will have a look at Ebay, but ordering this kind of adapter in the US takes too long to get here and probably cost too much for shipping and customs, I think making it ourselves is the fastest and probably cheapest way ;-) Thank you very much for all your help. Roger Link to comment Share on other sites More sharing options...
