Volflo's Rollcage Install Progress
JCviggen
Any word on tyhe new weight with the new lightening and the added cage?
Yes, i have done an Excel sheet with any bit of info i can possibly get/ estimate. Car has been weighed before the project this november and form the number i figure a resulting weight (gas tank half full, no driver)
2655 lbs :P
Would you remove the cylinder for the trunk? How much do the weigh? Any ideas on how to hold the trunk open then?
  • Replies 81
get my National-A-license for touring car racing.
sweet!
...no real championship i could use the 850 for...will probably buy a Golf GTI I or II , which quite easy and cost-efficient to maintain in Germany. Also there is much know-how and racing parts available....
too bad u'r not in sweden for that...
Or, fab up some "tailgate pins" so that it is still easy to open from the outside (instead of the cord idea inside the car). Just a thought from a newb.
BTW, that car is looking mean!
i like the cord idea. i had something different in mind, like using an alum rod to and put on the rear bumper. But your idea guys is a LOT better. Maybe i can even use a self-rolling up device. Anybody an idea what could be used for that along with a thin metal cord?
What about the front hood springs and the mechanics to hold the hood in place? How can i get rid of those? Using an alum rod?
You can find a place where two links of the hinges overlap in the open position and drill a hole through both of them for a pin. Then off with the springs, the hood will need two people to open then........
  • 3 weeks later...
the guy who did this is genius: the outer shell of the chassis when looked from behind at the c-column covers a big area: this makes a wagons body weaker compared to the sedan since the bracing is at a less of an efficient height. Because of this he constructed a beam underneath the roof. this construction is again drilled for less weight and more rigidity and weighs less than two pounds. (800 g)
i love him. he didnt charge a cent for that....
