mojojo Posted March 7, 2010 Report Share Posted March 7, 2010 I've tried searching, but am only able to find bits and pieces. I'm wondering what are the possibilities of installing different Volvo engines in to each chassis. As far as mounting points - what works? What to do for the accessories, etc? Scenario would be like installing S60 2.5T in to 850? I got to thinking after seeing the video of the white S70 on a dyno, with post title of "why build?". My cars are getting some mileage on them and I'd love to just go spend ~$1500 on a used, low mileage engine and be able to bolt-it in, instead of the down time of building an engine that's got so many miles as it is. Link to comment Share on other sites More sharing options...
maciekb2002 Posted March 7, 2010 Report Share Posted March 7, 2010 I've tried searching, but am only able to find bits and pieces. I'm wondering what are the possibilities of installing different Volvo engines in to each chassis. As far as mounting points - what works? What to do for the accessories, etc? Scenario would be like installing S60 2.5T in to 850? I got to thinking after seeing the video of the white S70 on a dyno, with post title of "why build?". My cars are getting some mileage on them and I'd love to just go spend ~$1500 on a used, low mileage engine and be able to bolt-it in, instead of the down time of building an engine that's got so many miles as it is. I have v70r engine , sitting in the shop . That is 2.4 block with head. You would have to change intake , cams and valve cover to make it fit to 850 . All mounting points are the same. It has oil cooler mounted on the oil pan. It is way better set up then radiator I want $750 if you pick it up Located 11757 ,ny Link to comment Share on other sites More sharing options...
mojojo Posted March 7, 2010 Author Report Share Posted March 7, 2010 I'm not in the market TODAY, but it's been in my head for a while, especially now after seeing all the 2.4T engines on eBay in the sub $1000 range. My black T5-R has quite a bit of miles on it, and I've toyed the idea of being able to drop-in a newer long block with little headaches. I guess maybe a FAQ with what would be required to mount different engines in to different chassis' would be ideal. I know this would require a vast amount of input/trials and very few members would be able to contribute, like my self so far I've only taken from a 95 850 Turbo to another 95 850 Turbo. Link to comment Share on other sites More sharing options...
Chilled man Posted March 7, 2010 Report Share Posted March 7, 2010 I have v70r engine , sitting in the shop . That is 2.4 block with head. You would have to change intake , cams and valve cover to make it fit to 850 . All mounting points are the same. It has oil cooler mounted on the oil pan. It is way better set up then radiator I want $750 if you pick it up Located 11757 ,ny acutally just then intake the valve cover will work rest is bolt in bolt out with some slight grinding nothing major Link to comment Share on other sites More sharing options...
johnloves850's Posted March 8, 2010 Report Share Posted March 8, 2010 I'd really love for someone to do something outside of the box, as far as a motor swap goes... Then I wake up. 2.5t swap would be pretty sweet, and IIRC someone here has done that. Can't remember their name off the top of my head. Hanks, maybe? Not sure. Link to comment Share on other sites More sharing options...
ozzimark Posted March 8, 2010 Report Share Posted March 8, 2010 Then I wake up and remember that our drivetrain sucks if we want to put down any decent amount of power. Edited to make it true for me. A robust AWD setup would be amazing. As far as the engine goes, just a straight 2.5T swap seems kinda lacking to me. I'd rather take an RN based 2.3L T5 engine block, put an 05+ dual VVT head on, make a VVT controller that operates based on load and rpm, and spin the thing for all it's worth with a medium sized turbo :ph34r: Link to comment Share on other sites More sharing options...
mdlimy Posted March 8, 2010 Report Share Posted March 8, 2010 Edited to make it true for me. A robust AWD setup would be amazing. As far as the engine goes, just a straight 2.5T swap seems kinda lacking to me. I'd rather take an RN based 2.3L T5 engine block, put an 05+ dual VVT head on, make a VVT controller that operates based on load and rpm, and spin the thing for all it's worth with a medium sized turbo a 2.5t with a big turbo would do better than that setup...and we all agreed that the cvvt is almost useless for performance gains... Link to comment Share on other sites More sharing options...
Chilled man Posted March 8, 2010 Report Share Posted March 8, 2010 a 2.5t with a big turbo would do better than that setup...and we all agreed that the cvvt is almost useless for performance gains... 01 T5 Motor + M56 K24 R Manifold greens = more whp then your car can handle with out a LSD And wont have to build or put a bottom end in Link to comment Share on other sites More sharing options...
mdlimy Posted March 8, 2010 Report Share Posted March 8, 2010 01 T5 Motor + M56 K24 R Manifold greens = more whp then your car can handle with out a LSD And wont have to build or put a bottom end in all you gotta do is source a motor out of a wrecked p2 R and grab an m56 swap and you would be golden, so easy, anyone could do that entire setup for about 3k (without lsd ofcourse) of course justin already has all that stuff times 3 :lol: Link to comment Share on other sites More sharing options...
Chilled man Posted March 8, 2010 Report Share Posted March 8, 2010 all you gotta do is source a motor out of a wrecked p2 R and grab an m56 swap and you would be golden, so easy, anyone could do that entire setup for about 3k (without lsd ofcourse) of course justin already has all that stuff times 3 acutally I do minus the LSD acutally Thinking for my 98R 99 S70 T5 Motor M56 K24 R mani blues more whp then the one wheel can handle Link to comment Share on other sites More sharing options...
mdlimy Posted March 8, 2010 Report Share Posted March 8, 2010 acutally I do minus the LSD acutally Thinking for my 98R 99 S70 T5 Motor M56 K24 R mani blues more whp then the one wheel can handle ditch the 99 motor and just find an 01+ t5 motor, youll be kicking your self when the k24 takes out the bottom end on that motor, and i know you can source a new motor for probally next to nothing if you are parting a car. screw the 98R, put all that in the xc :D Link to comment Share on other sites More sharing options...
Chilled man Posted March 8, 2010 Report Share Posted March 8, 2010 ditch the 99 motor and just find an 01+ t5 motor, youll be kicking your self when the k24 takes out the bottom end on that motor, and i know you can source a new motor for probally next to nothing if you are parting a car. screw the 98R, put all that in the xc that is the list for the XC with a 01T5 motor so a second with a 99 motor since I already have both Link to comment Share on other sites More sharing options...
johnloves850's Posted March 9, 2010 Report Share Posted March 9, 2010 01 T5 Motor + M56 K24 R Manifold greens = more whp then your car can handle with out a LSD And wont have to build or put a bottom end in I would have absolutely loved this in my 855 I don't know why, but I'm not looking for go fast parts in my T5. Link to comment Share on other sites More sharing options...
mdlimy Posted March 9, 2010 Report Share Posted March 9, 2010 I would have absolutely loved this in my 855 I don't know why, but I'm not looking for go fast parts in my T5. i know why, because its a good reliable daily driver and you have a dope ass diesel 245 to work on...you bastard, still jealous :lol: Link to comment Share on other sites More sharing options...
z31jaime Posted March 9, 2010 Report Share Posted March 9, 2010 2010 s-80 v-8 swap would be hot! Link to comment Share on other sites More sharing options...
