Mesoam Posted March 10, 2010 Report Share Posted March 10, 2010 whats the deal with the 01 trans's failing? is it much like the s80's where failure is basically inevitable or is it preventable with proper maintenance? also i've heard about modifying the fluid pressure to improve the gear-tronic shifting characteristics, has anyone done that here? Link to comment Share on other sites More sharing options...
flyfishing3 Posted March 10, 2010 Report Share Posted March 10, 2010 Isn't that a gm tranny? I know the o4r gt is a gm tranny Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted March 10, 2010 Report Share Posted March 10, 2010 whats the deal with the 01 trans's failing? is it much like the s80's where failure is basically inevitable or is it preventable with proper maintenance? also i've heard about modifying the fluid pressure to improve the gear-tronic shifting characteristics, has anyone done that here? The valve body design is garbage. That along with poor programming from the factory has given these a reputation This problem went on until some time in 02. Failure on AWD units is higher, but many exhibit very poor shift quality. Best choice is to go 03 and up. Isn't that a gm tranny? I know the o4r gt is a gm tranny The 04R GT tranny is a 5spd aisen warner unit. GM trannies were only installed on 6 cyl engines. Link to comment Share on other sites More sharing options...
Chilled man Posted March 10, 2010 Report Share Posted March 10, 2010 The 04R GT tranny is a 5spd aisen warner unit. GM trannies were only installed on 6 cyl engines. / on the XC90 and S80s with proper maintence , fluid changes , newer software you shouldnt have any issues the 01 I had was mint I got it at 32,000 miles and had the software change and everything else done as soon as I got it. My uncles has 190,000 miles + and hes never had a isssue both 01T5 only tranny issue I have seen is on the 02XC but that had 220,000 on it so ... oh and my 01XC that had 165,000 when it went Link to comment Share on other sites More sharing options...
flyfishing3 Posted March 10, 2010 Report Share Posted March 10, 2010 The 04R GT tranny is a 5spd aisen warner unit. What's the wager? Link to comment Share on other sites More sharing options...
Chilled man Posted March 10, 2010 Report Share Posted March 10, 2010 What's the wager? if were right you keep the center plate for the drive shaft if were wrong you send it to firepuma I have picutres .... 00 5 speed auto / only R and NA in 00 were 5 speed 01-04 5speed auto / unsure when it changes in the C70 thou 05+ 6speed auto If you get a 01-02 I would suggest a tranny cooler , look for the C70 one that would fit all but perfect and should be a pretty close to direct drop in. The wifes C70 has one its pretty neat Link to comment Share on other sites More sharing options...
Young Burnsy Posted March 10, 2010 Report Share Posted March 10, 2010 Where should said tranny cooler go Justin? Link to comment Share on other sites More sharing options...
Chilled man Posted March 10, 2010 Report Share Posted March 10, 2010 Where should said tranny cooler go Justin? where you would put a FMIC in or if you have a FMIC put it up behind the grill those would be the two most optimum placement areas. Link to comment Share on other sites More sharing options...
Mesoam Posted March 13, 2010 Author Report Share Posted March 13, 2010 so how about the mod for improving the GT function? Link to comment Share on other sites More sharing options...
Chilled man Posted March 13, 2010 Report Share Posted March 13, 2010 so how about the mod for improving the GT function? talk to lucky Link to comment Share on other sites More sharing options...
bdimag Posted March 13, 2010 Report Share Posted March 13, 2010 mine crapped out @ about 110k i think... like 10 months after i bought the car. In the United States, the AW55-50 is used in the: • Saturn Ion and Vue, (AF23-5 in the 4 cylinder and AF33-5 in the V-6) • Chevrolet Equinox and the Pontiac Torrent, (AF33-5) • Nissan Altima, Maxima and Quest, (RE5F22A) • Saab 9-3 and 9-5 • Volvo C70, S40, S60, S70, S80, S90, V40, V50, V70, XC70 and the XC90 Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted March 14, 2010 Report Share Posted March 14, 2010 What's the wager? Your finest fly rod :D Link to comment Share on other sites More sharing options...
flyfishing3 Posted March 14, 2010 Report Share Posted March 14, 2010 yeah, i've done a little research. i'm going to back away from this............ Link to comment Share on other sites More sharing options...
Chilled man Posted March 14, 2010 Report Share Posted March 14, 2010 yeah, i've done a little research. i'm going to back away from this............ :lol: Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted March 14, 2010 Report Share Posted March 14, 2010 yeah, i've done a little research. i'm going to back away from this............ hahahahahaha Would you like me to PM you my shipping address?! :D Link to comment Share on other sites More sharing options...
