FAST850R Posted March 17, 2010 Report Share Posted March 17, 2010 Hi, I got check engine light 2 weeks ago. A mechanic pulled the code and reset it for me. It came back a few days later. So since the code indicated VSS, I replaced it and tried to reset the code by disconnecting the battery. As soon as I started the engine, the light was still there. I took my car to Autozone, and they don't do OBD II code service anymore. I don't want to take it to a shop and paid $20 to reset the code. Is there any other way to reset the light? Also, I sometimes get tracs off and ABS light, but it goes away by itself. Does this mean time for rebuild ABS module? Link to comment Share on other sites More sharing options...
FAST850R Posted March 17, 2010 Author Report Share Posted March 17, 2010 Or, can anyone recommend me an OBD II code reader? I might just buy one and reset the light myself. I found it but the price range is from $29~$200. Thanks. Link to comment Share on other sites More sharing options...
the commissar! Posted March 17, 2010 Report Share Posted March 17, 2010 how long did you leave the battery discon...it takes a while for the memory to fade... If you plan on working on this or any OBDII car it is worth the investment. Link to comment Share on other sites More sharing options...
FAST850R Posted March 17, 2010 Author Report Share Posted March 17, 2010 how long did you leave the battery discon...it takes a while for the memory to fade... If you plan on working on this or any OBDII car it is worth the investment. I disconnected the battery while I was replacing the VSS. I think it was about 20~30min... When I look at the car from the front, I look down the battery, and I disconnected the one on the left. Link to comment Share on other sites More sharing options...
Bah Posted March 17, 2010 Report Share Posted March 17, 2010 idk if this works on OBDII cars, but on the 93 the 5 flicks to position 2 and on the fifth flick start the car, works to reset tranny codes(OBDI atleast...) Give it a shot, otherwise i guess just leave the battery undone longer? Link to comment Share on other sites More sharing options...
FAST850R Posted March 18, 2010 Author Report Share Posted March 18, 2010 idk if this works on OBDII cars, but on the 93 the 5 flicks to position 2 and on the fifth flick start the car, works to reset tranny codes(OBDI atleast...) Give it a shot, otherwise i guess just leave the battery undone longer? Thank you for the reply. I will try your method. If it doesn't work, I will disconnect the battery longer, then if it doesn't work, I will buy an OBDii reader. Link to comment Share on other sites More sharing options...
(n)A-GAME Posted March 18, 2010 Report Share Posted March 18, 2010 Batt needs to be disconnected for at least 15 minutes iirc to reset codes. But the better question is why you're getting the code in the first place? Are you sure the work was done properly? But +1 to the suggestion that you buy a code reader. You can pick up a decent Actron for $30 on Amazon. Link to comment Share on other sites More sharing options...
FAST850R Posted March 18, 2010 Author Report Share Posted March 18, 2010 Batt needs to be disconnected for at least 15 minutes iirc to reset codes. But the better question is why you're getting the code in the first place? Are you sure the work was done properly? But +1 to the suggestion that you buy a code reader. You can pick up a decent Actron for $30 on Amazon. I got the code due to faulty VSS. I don't know whether actual VSS is bad or just wiring problem, but I just replaced it anyways. I need to reset the check engine light so I make sure VSS working properly. Anyway, I am sure I disconnected the battery more than 20min, but it didn't reset the light. It reset everything though, clock, radio, and alarm. Link to comment Share on other sites More sharing options...
Volvo5.0 Posted March 18, 2010 Report Share Posted March 18, 2010 What year is the car? 96 and later, then it probably is the abs/tracs module. Link to comment Share on other sites More sharing options...
brick-a-brac Posted March 18, 2010 Report Share Posted March 18, 2010 You need to make good friends with someone who has the Volvo Scan Tool, or luck out on eBay and snag the occasional one that comes up for sale (be prepared to pay north of a grand for it, though). Many of the commercially available OBDII readers cannot clear system codes other than engine and emissions. Link to comment Share on other sites More sharing options...
Volvo5.0 Posted March 18, 2010 Report Share Posted March 18, 2010 I've got a VST, but it looks like you're a long way from Md. :) Link to comment Share on other sites More sharing options...
the commissar! Posted March 18, 2010 Report Share Posted March 18, 2010 I disconnected the battery while I was replacing the VSS. I think it was about 20~30min... When I look at the car from the front, I look down the battery, and I disconnected the one on the left. That would be the hot wire...shouldn't you pull the ground...I can never remember so I do both when I need the power off the car. You could also just pull the module. Then it is cold for sure. Also as said you need to fix that problem not just reset the light. Hopefully you have it worked out by now... Link to comment Share on other sites More sharing options...
