esitzler Posted March 20, 2010 Report Share Posted March 20, 2010 Hi all. Well I think I am hosed... My 99 S80 was running quite rough and I cleaned the ETM, changed the plugs, checked the coils, and finally did a compression test. #3 cylinder is showing a 0 compression. Crap. Has anyone ever done the rings on that engine and how hard is it? The #3 plug was quite fouled with oil, so I think it is the rings. Anyone interested in buying a 99 S80 with a bad cylinder?? I think I'm going to go back to the 850 GLT. I loved that car. Thanks, Eric Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted March 20, 2010 Report Share Posted March 20, 2010 There is 99% chance you burned an exhaust valve. Link to comment Share on other sites More sharing options...
esitzler Posted March 21, 2010 Author Report Share Posted March 21, 2010 Would the plug have oil on it if it is the valve? The plug I removed was fouled pretty bad with oil and was quite black. The new plug was wet with oil after only a few miles of driving. Thanks for the reply. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted March 22, 2010 Report Share Posted March 22, 2010 It's probably a combination of raw fuel and oil, yes a fouled plug would be normal. Link to comment Share on other sites More sharing options...
TainterRacing Posted April 3, 2010 Report Share Posted April 3, 2010 Most of the time Bad rings will still have some compression just very low with 0psi I would say a valve as well. Hi all. Well I think I am hosed... My 99 S80 was running quite rough and I cleaned the ETM, changed the plugs, checked the coils, and finally did a compression test. #3 cylinder is showing a 0 compression. Crap. Has anyone ever done the rings on that engine and how hard is it? The #3 plug was quite fouled with oil, so I think it is the rings. Anyone interested in buying a 99 S80 with a bad cylinder?? I think I'm going to go back to the 850 GLT. I loved that car. Thanks, Eric Link to comment Share on other sites More sharing options...
rbodor3 Posted April 3, 2010 Report Share Posted April 3, 2010 leakdown test will show you, pretty simple and easy if you have an air compressor. Leakdown tester @ harbor freight is like $40 IIRC. Listen for it coming out of your tail pipe will indicate crapped out valve. Either way you'll want to pull the head if it is a bad piston ring, and at that time you'll immediately notice a broke exhaust valve :P Link to comment Share on other sites More sharing options...
